I don't post here often but I do stop by almost every night to see what you guys are up to.
I've had a Pinasco 177 2 port kit sitting on my shelf for a few years now. It's time to play with it.
The plan is to put it in my Allstate replacing the VNA lump.
I'll be replacing seals, bearings and the cruciform.
Gearing is to remain stock 3 speed.
Clutch: Cosa with DRT 23t gear cog for 67/68 primary
Crank: ? Should I go with a 57mm or 60mm stroke?
https://www.sip-scootershop.com/en/product/long-stroke-crankshaft-pinasco_46006100?q=Pinasco%20crank
I'm also thinking of replacing the Pinasco head with this MMW head.
https://www.sip-scootershop.com/en/product/cylinder-head-malossi-mk-iii-177-cc-by-mmw-177-pinasco-alu_38348410?q=Pinasco%20177
Has anyone played with one of these yet?
Carb: I have a 20/20
Is that enough carb or should I go with a 24/24?
I'm sure there are things I'm missing and plenty of questions I'll have to ask.
What do you think of the plan so far?
