@greasy125 avatar
@greasy125 avatar
so, I know how it all goes together and all that. but uhhh... what if you're presented with this?
FFFFffff... right?
baby and bath water? just suck it up butter cup and order another?
it's going out on a client's bike, so I can't be playing around. I was contemplating sealing it up with motoseal or devcon.
but I ask the peanut gallery, what say you?
also I have to order all the other shit for the install too... so what's a tank at that point? no biggie.
looking for the quick, dirty, easy fix here.
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
I would think the right plastic epoxy would be OK, because it mildly melts the two pieces as it cures and kind of fuses them together. Wouldn't think 2T would degrade it, at least not with the right formula.
Personally I'd get a new one. Oil likes to find any gaps. I wouldn't trust it. Especially since you're placing an order anyways
@orwell84 avatar
@orwell84 avatar
If you were doing it for me, I would want it replaced, but I wouldn't gripe about the cost. If I were you, I'd rather put a new one in than dick around with goo and potentially have to pull the whole shit show out again if it comes back. Calculate cost of tube o' goo, time spent gubing on the goo, testing for leaks…You get the idea…
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Oh 100% I'd just buy a new one. But he asked if it could be fixed - I bet it can
@orwell84 avatar
@orwell84 avatar
Sure it can. And if it was the last one on earth, it would be totally worth it.
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Laughing emoticon
@dirty30dillon avatar
Yes
Yes
I know it sucks, but if you were stuck on using it to avoid trashing it, I would 2-part epoxy the halves together, and then coat with this to ensure there were no leaks.
https://caswellplating.com/lantern-font-sealing-kit.html
Caswell is the best gas tank sealer, hands down. And while this is a new product, this will stop any leaks AND further adhere the two halves.
You are in luck, I was given FOUR healthy oil tanks that I need to figure out how to dispose of responsibly. Or maybe I'M in luck, can you help me out here please? Eyelashes emoticon
I can dump in some gas and check for leaks, cheap insurance!
@greasy125 avatar
@greasy125 avatar
kinda my thoughts. may save it for another day and another project. I don't want some yahoo yelling at me that there's 2T all over his garage floor and bike so it might be one for me to play with and eat it with a new one. don't wanna gamble on a come back!
@greasy125 avatar
@greasy125 avatar
thank you for being a voice of reason. my chaos monster instincts were kicking in.
for me? fine. but for a client, nah. it's all gotta be high line.
found a sight glass and gasket but no lock ring or crush gasket. of course. so not I'm all, well F this noise. I'm gonna order doubles of ALL of it. and I'm sure I'll sit on it till forever until John or Birbs hits me up for some other rando parts and I wind up sending it to them as part of a care package. or CM2 texts in blind panic on the eve of a rally. yeah, I got that bro!
*laughs*
@greasy125 avatar
@greasy125 avatar
a steady hand on the rudder is always appreciated. thanks for talking me off the edge!
@greasy125 avatar
@greasy125 avatar
D-money, thanks for the heads up on that. I'll probably use that and shelf it for in-house use. ie: my shitbox bikes.
I don't usually like to play fast and loose with client bikes unless it's a dire situation. homeboy is totally chill so I'm not in a time crunch, just kinda pissy that I got this sent to me, opened it and it was all:
*blow raspberry*
*gestures wildly with hands*
*mutters under breath mother fucker*
~sighs deeply~
nothing comes easy sometimes.
@greasy125 avatar
@greasy125 avatar
V-man, you gots my addy. shoot me a PM and let me know how much to pay pal you. I'm down for at *least* one. two if you want.
but please, let me pay you!
@chandlerman avatar
Lucky
71 Days Since Last Explosion
Lucky
@chandlerman avatar
If you're serious about wanting to move those oil tanks to a good home, I'm down for at least one, as well.
Lemme know and I'll PM you my address AFTER you tell me your Venmo or Paypal
@veloce_vulture avatar
Tuk Tuk.
Tuk Tuk.
It's sorted clearly, but for fun. I would have used gel superglue after having it cool off in a refrigerator for a few minutes. At least if nothing else, if it didn't work it's clearly done and not sitting in your valuable real estate after.
Yes
Yes
*blow raspberry*
~sighs deeply~
I hear you on this, if the customer isn't frothing at the mouth and it's happy to pay for your time, get the right part for your own sake.
I worked at the only NYC moped shop for years,: all vintage, all the time. So I'm completely on board with choosing what method/means is best per customer and situation. The WORST thing is to get a call from a customer who just picked up a bike that something went wrong.
But I digress. I've used Caswell on a dozen tanks, most of which simply HAD to be saved (like the Honda MB5's notoriously "porous" and impossible to find tank) and cannot recommend any other sealer.
The little lantern font sized setup is great for smaller stuff, but they make bigger packages for larger tanks. The standard sized one would probably do 2 large frame tanks.
@orwell84 avatar
@orwell84 avatar
I get it though, I often keep broken VW stuff and end up fixing it. I was welding up some old backing plates I had sandblasted clean and people on my bus forum were like…just get new ones you cheap ass.
Sure enough, the new ones have a stamped ridge that the drums rub on. They made quite a racket going around corners until 1500 miles of dynamic machining quieted them down.
Premix
PX150E
PX150E
FFFFffff... right?
That tank looks like it was precisely cut in two at the seam! But it looks brand new and cut on purpose that way. With special plastic repair epoxy, it can be bonded again, and covered with JB weld all the way around the seam, which is where cracks start and result in leaks.
If it were mine, that is how I would fix it. But I agree that replacing it would be the preferred option.
[ Time: 0.0257s ][ Queries: 4 (0.0118s) ][ live ][ 313 ][ ThingOne ]
