Damn it that's the second that I've broken the clip on. I HATE PLASTIC CLIPS
So I've just order a couple more. I use the black ones from aliexpress instead of the blue oem ones.
2022 Honda PCX 150A, 2018 GTS300 [sold] & 2015 GTS300 Super [sold]
I like that color scheme. On mine, I use a small screwdriver on the left-side (if you are facing it) gap, and pry it out gently from left to right.
@juan_orhea avatar
S150 '09, Beo 500ie '08
@juan_orhea avatar
Those badges, like the round one in the transmission cover, and the many many tabs on the plastic panels throughout scooterdom, are simply designed/doomed to fail.
Not relevant to the original part, but I've discovered that it is possible, if you can get a body panel tab in place with plastic cement, to add a LOT of strength to a broken tab. I scuff/sand the area and add 2-4 layers of two-part epoxy (not the quick-cure kind) to saturate little pieces of fiberglass cloth overlaying the joint. It ain't pretty but it is quite strong and can be shaped/drilled with a Dremel.
⚠️ Last edited by Juan_ORhea on UTC; edited 1 time
The best tool i found for removing this badge is a table knife.
@phaskins avatar
2006 250ie
@phaskins avatar
2006 250ie
Not sure if this would help but you might consider taking a file to the lip of the tab. Round it off just enough to make it easier to release.
@shebalba avatar
@shebalba avatar
I'm digging the various badge options that are popping up on the interwebs. A relatively inexpensive way to add a piece of flair to your ride and the selection seems to be expanding.
I have noticed the clear (polyurethane?) coating does haze and and yellow faster than the OEM.
I wish there were matching options for the fender crest badge.
@tidwillow avatar
GILERA FUOCO II & GTS 300 SUPER
@tidwillow avatar
There are matching fender crest emblems! You gotta search for them. I got my front emblem and fender crest from Alibaba about a year ago. Then not to long ago I received the wheel bearing center cap to match. The emblems being plastic I have snapped a few over the years. I just assumed the hot and cold fluctuation got the best of the plastic tabs..
@25bikez avatar
2022 Liberty 150S-"Meg"-SOLD
@25bikez avatar
You have noticed that the two retaining tabs are different, yes?
The badge is only designed to pivot in one direction when it comes off.
DAMN IT 🤬🤬
broke two more yesterday. luckily I had some spares
steelbytes wrote:
DAMN IT 🤬🤬
What are you doing to break them? I must have removed hundreds in my time, and it's never been a problem. Flat-bladed screwdriver in at the middle of the right-hand side of the badge (looking at it) , twist, and out it pops. There's even a little cut-away to show where to place the screwdriver...
that's what I do but guess I'm jsut clumsy or maybe these aftermarket black ones that I prefer are jsut more brittle
@tidwillow avatar
@tidwillow avatar
It's the low quality of the plastic. Then add cold/hot weather they break down quickly. Smart to buy a few at a time with these cheap ones...
[ Time: 0.0132s ][ Queries: 4 (0.0036s) ][ live ][ 313 ][ ThingOne ]
