Sat Jun 04, 2022 6:08 am
2007 MP3 250
Joined: 25 Feb 2020 Posts: 24 Location: SW Ontario Canada
2007 MP3 250
HI
This matter has cropped up on the forum in the past, but my personsonal reason for need of a Side stand was never really , being failure of the Tiltlock control! I am now in my 90's and have owned two MP3's In both I have had a failure of the Tiltlock, leaving me wondering if I could possibly get off and use the centre stand without dropping the Vehicle. Due to age and health my strength is not what it once was, and I bought an MP3 to save the need to balance the weight. I have another scooter that has both side and centre stands, making things much easier.
Yes, I know the tiltlock is usually reliable, but for my peace of mind..........
If anyone knows of an aftermarket sidestand that would do the trick, I would appreciate hearing form them.
Peter.
Sat Jun 04, 2022 11:34 am
Gilera Fuoco 500ie
Joined: 11 Oct 2009 Posts: 4396 Location: Netherlands Olst
Gilera Fuoco 500ie
its possible the first 125cc didn't have a tilt lock so it came with a jiffy and a center stand
Sat Jun 04, 2022 5:19 pm
2007 MP3 250
2007 MP3 250
Thanks for the prompt response. I will do some research into the 125 and see how it is set up. Failing that I may have to consider fabrication .
Tue Jun 07, 2022 4:36 pm
Wed Jun 08, 2022 10:43 am
2007 MP3 250
2007 MP3 250
Yes, it looks good...does it make use of the centre stand frame mount? I will take another look if and when I have the ##@*$ Tiltlock working!
Thanks for your input
Cheers
Peter.
Wed Jun 08, 2022 10:11 pm
it was not mounted using centerstand mount. it was welded to side frame rail. I dont have the lower side fairings. that would likely need trimmed to fit. it was 100% custom. but not that hard as far as custom goes. It was really worth the effort. bike was cumbersome using the center stand.
