@j_scott avatar
2018 GTS 300
@j_scott avatar
2018 GTS 300
Briught her home yesterday. I decided to hook up a OBDII. I got this code stored in.
Its a Vehicle Speed Sensor Range/ Performance
I dont think that has to do with the idle tho :/
My idle is slightly elevated from a new spark plug. 1720rpm
Is the vehicle speed sensor on the front wheel?
Thanks,
1720rpm is in the normal range for idle. 1650-1750 I find i normal
There are two sensor one, one on the front and one on the rear. The combo of these is used for two purposes, ABS and ASR
The speedo on my Supertech is driven by the rear wheel sensor. Easily seen by revving the bike on the stand.
I suggest recalibrating the ASR (which should be done periodically anyway)
@j_scott avatar
2018 GTS 300
@j_scott avatar
2018 GTS 300
Thanks, i think i know what sensors your are talking about. I looked at the front and gave it a dry wipe down but didnt see any obvious debris. I will clear the code if i can. ASR seems to work/respond good and no check engine light on at the moment on the dash. Hope it doesnt come back on.
[ Time: 0.0092s ][ Queries: 3 (0.0016s) ][ live ][ 313 ][ ThingOne ]
