Gts 125
Gts 125
I have an ongoing throttle body sensor problem on my gts 125 ( 2020 iget )
It first started at around 1800 miles, it's now on over 8,000 miles and still doing the same thing.
I have lost count of the amount of times it has been in to get "fixed". When I get it back from the garage everything seems fine with it. Soon as I clock up a couple of hundred miles on it the same old fault appears. It has had a new ECU fitted and thar didn't help.
It's fires up OK ( most of the time ) as soon as the throttle is pulled back it starts to cough and splutter then cuts out. Once I have done a mile or two it runs fine again.
The garage reckon i should switch back to a standard exhaust rather then the scorpion one I have had on since I bought it brand new.
Any help is appreciated.
Cheers.
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
Try it with the standard exhaust. Your neighbours will be well pleased.
(Scorpion exhausts are shit anyway)
Do you have the catalytic installed in your Scorpion? If not then it could make a difference. Doesn't hurt to try the standard exhaust for a few hundred kms.
[ Time: 0.0098s ][ Queries: 3 (0.0028s) ][ live ][ 313 ][ ThingOne ]
