@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
Hi Folks
My Vespa GTS 300 suddenly has like a stiff feeling - kind of making me make wider turns etc. On straightaway it's totally fine, and it's even fine turning……it just feels stiffer and not like butter and fluid as it was. Just happened when I was riding the other day. I checked my psi and it's 31 in front and 29 in back so that's all good. Any thoughts?? It is a bit hard to explain but it's just a feeling of stiffness when riding and it's not letting me turn handlebars as fluidly. I was hoping it was tire pressure but it's not.
@jkj-fz6 avatar
@jkj-fz6 avatar
I don't think this is the answer to your question, but are you sure it's supposed to be 31 in front and 29 in back? Usually the rear is higher than the front.
@jkj-fz6 avatar
@jkj-fz6 avatar
Can you feel resistance in the steering when the scooter is not moving?
Is there anything wrong with the brakes?
⚠️ Last edited by JKJ-FZ6 on UTC; edited 1 time
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
Was just going by what some people said on here.
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
When I am at red lights Etc I turn from side to side and see if it feels fine. It's just then if I am riding and want to turn there is a bit of resistance that wasn't there a few days ago and I have to make wider turns and lean in it seems
@jkj-fz6 avatar
@jkj-fz6 avatar
Sounds like you got it backwards, that's all. It wouldn't have any effect on the steering unless the pressure was much lower than that.
@harbinger avatar
@harbinger avatar
Yep, that minor a difference is well within tolerance and steering would be fine. Tire pressure to me is a personal preference thing and go with what feel right as long as it is within tolerance. People weigh different amounts some have a lot in the top case etc etc. If I'm filling the top case with heavy groceries (beer) I don't adjust my pressure for the trip home.
@jkj-fz6 avatar
@jkj-fz6 avatar
Just a thought -- You're fairly new to that scooter, aren't you? Maybe you're adjusting to the way it handles and leaning more, or starting to feel your counter-steering.
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
I was hoping it's a tire pressure thing but it's not. Any thoughts would be appreciated.
Strange steering 'feelings' could be several things. It could be the beginning of a notch in the steering bearings, it could be engine swingarm needle bearings breaking up, it could be engine support silent blocks disintegrating.
Or, as above, if the GTS is new to you, and you're comparing to an LX say, then it could just be that you need to become better acquainted,
I don't see the subtle tire pressure difference as a big deal, though as JKJ states you've got the pressures backwards.
May just be you adjusting to the ride..... Nerd emoticon
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
Perhaps it's just me adjusting I guess…….it's just that after 800 miles it suddenly feels a bit different is all. I guess it's not a big deal
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
Just got this scary message via PM - ??? Is this spam or what
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
Check the decals or metal plate for PSI required.
@guzzi_gal avatar
Gigi, '13 GTS 300ie Touring
@guzzi_gal avatar
Thescooterbud runs a scooter parts web store. Beyond that, I don't know much about him or his site. Scooter emoticon
These are the manufacturer's recomendations.
The spam question was answered in its own thread. Let's drop that subject in this one.
@wleuthold avatar
@wleuthold avatar
At only 800 miles, it can't be a wear issue.
I have replaced worn steering head bearings, but both times after 50,000 miles.
I believe that you are new to the scooter and getting used to the way it handles.
But just in case, have someone familiar with the GTS ride it and offer their thoughts.
Bill
@mjrally avatar
@mjrally avatar
Have you been poking around in the headset/ horn cast lately? Theres a lot of wires and brake cables in there. If any of those became dislodged and jamming/fighting, it could cause an issue.
Like Bill said, have someone familiar with a GTS ride it and ask their thoughts. If you cant, go to your dealer and have them ride it. Bad steering can turn into a safety issue.
Weird, though, that it seems to turn fine when not actually riding... Nerd emoticon
@mjrally avatar
@mjrally avatar
Honestly, who knows!?! Until we get hands on, were all guessing at something posted on the internet! Thats why I agreed with Bills idea, have someone else check it out.
@seamus26 avatar
1979 P200E (sold) / ZNEN Amore 150 (sold) / Genuine Buddy 170i / Genuine Stella 4T /Aprilia Sportcity One 50
@seamus26 avatar
I'd lean toward worn marzlevanes. The original machine had a base plate of pre-famulated amulite surmounted by a malleable logarithmic casing in such a way that the two spurving bearings were in a direct line with the panametric fan. The latter consisted simply of six hydrocoptic marzlevanes, so fitted to the ambifacient lunar waneshaft that side fumbling was effectively prevented. When the marzelvanes wear irregularly the side fumbling is noticeable.
Yeah ... I've got nothing.
@25bikez avatar
2022 Liberty 150S-"Meg"-SOLD
@25bikez avatar
Put it on the center stand and put a jack (and soft pad) under the front frame and jack until the front wheel is off the ground.
Does the wheel turn freely side to side? Any obvious notchiness or grunching?
Get on the floor and look up into the area where the steering tube enters the frame. Anything look like it's binding? Any debris jammed up there? Any play front to back?
Look at the suspension arm at the front wheel. Anything jammed into the pivots? Maybe a piece of road trash? Is there a bolt or nut backed out or rubbing?
Watch the front wheel as you lower the jack. Does the suspension flex as the weight comes back to the front end?
Is the fender binding/rubbing underneath the leg shield?
Are any cables binding or out of their clips?
Take it step by step: look, manipulate, listen, feel. Get a flashlight and a mirror to look behind things.
@tor2ga avatar
@tor2ga avatar
Left fumbling and right fumbling are two different problems. Has this bike ever been in Australia?
have you been hitting any bumps or holes hard enough that the front suspension has 'bottomed out' (reached the end of it's vertical travel)? the shock travelling up the front fork could damage the steering bearings.
I think it was hitting way too many potholes and speeds that were too fast as well as too much corrugated / washboard roads that have damaged my steering bearings. GTS steering bearings
PS and fix your pressures as everyone else here has mentioned although I'm not really sure that that's the cause.
⚠️ Last edited by SteelBytes on UTC; edited 3 times
@berto avatar
@berto avatar
I think you just bought this bike new from the dealer a couple months ago? Is it feasible to have them look it over?
@dooglas avatar
@dooglas avatar
Reading RocklandDad's experiences since he recently acquired a new GTS, it is hard to imagine that would be his problem.
Sometimes it's the tire. I have felt strangeness like that on old tires, changed them, and had steering feel normal again. The bike would try to turn in or flop to the inside such that I had to push excessively on the the inside hand to keep it from turning in. Maybe it's your new tires
SilverWing 600-- 4nprevious Vespa
Remember 2 wheelers are leaned, not steered, except at. real slow speeds.
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
The other day when I checked my PSI when this all started happening, I noticed they were just about the settings they were supposed to be (as per sticker in glove box) but I thought perhaps since it's been 400 or so miles since last service that maybe they has PSI higher than normal........and that is what I was used to......So, I put my back at 42 (recommended 37.7) and my front at 32 (recommended 26) and it feels back to normal.
Perhaps it's all in my head.......but I will take it!! 30 miles today and was pissed I couldn't stay on due to family obligations. lol
@dooglas avatar
@dooglas avatar
I'm not sure where you are getting some of these numbers. Piaggio recommends 1.8 bar (26 psi) in front and 2.0 bar (29 psi) at rear for one up riding and 2.2 bar (32 psi) at rear for 2-up riding. A heavier rider will probably want to go a little higher than 29 at the rear. Having said all that, adding another couple of pounds (front and rear) if you like the feel of that will certainly not doing any harm, but I'd think 42 psi at the rear while riding one up would make your scooter ride like an ox cart. Just saying.
@jakem avatar
Vespa Sprint Sport S 125cc
@jakem avatar
Has the scooter had its first service at 620 miles (1000km)?
The Primaveras (and I assume the larger Vespas as well) are meant to have the steering adjusted after the first 620 miles.
After the first service, it's never routinely adjusted again - only inspected.
42?
forty two?
FORTY TWO?
Seriously no, that's so far wrong it's not even funny
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
Check this out......it states clearly 37.7 for rear.
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
Yes, I had the first service done......I had it done at 477 miles since they were replacing my fuel pump which was faulty at that time.
RocklandDad wrote:
Clearly states 37.7 for rear.
If you read the whole plate you'll see it's talking about with 2 large adults on it. What did i just say? We'll it says gross vehicle weight of 352kg (98 front and 254 rear). The wet weight of gts is about 160 so to get 350 would require 2 x 95kg people. Yikes.
That is the maximum Gross Vehicle Weight pressure, 2.6 bar (37.7 psi). That's the maximum for driver and passenger, as stated on the sticker inside the glovebox. Driver alone is less - depending on your weight. Piaggio suggest 2.2 bar - personally I like it a little more, 2.3 or 2.4, and I weigh ~175lb. 42 psi (2.9 bar) is way over the limit for safe riding on *this Vespa*. The tyre itself may have a higher maximum on it (they vary) but that's to prevent failure...
42 psi is NOT wise. You risk having a less than adequate contact patch and blowing out if you hit a pothole.
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
What do you have front and back?
1.8 and 2.3 bar (26 and 33 psi) at the moment. Rides like a dream.
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
I will do that as well.
@rocklanddad avatar
2022 VESPA GTS 300
@rocklanddad avatar
2022 VESPA GTS 300
Thanks for your help with this. So many different people telling me different things.....but I followed your guidance and mine is back to riding dreamy.
[ Time: 0.0158s ][ Queries: 4 (0.0080s) ][ live ][ 313 ][ ThingOne ]
