PX 125
PX 125
Hi All
Im brand new on here so be gentle as im not too tech minded. Would normally go to my pal who has 2 stroke in his veins but ive relocated so im on my own.
I have a px 125 upgraded to a pinasco 177 and all was running great. I had to let it sit for a few years with old fuel so decided to drain the system of oil and petrol. unfortunately the fuel pipe split and disintegrated so ive renewed both oil ( Auto lube) and petrol pipe and the scoot started and ticks over as it should.
The problem i have is when i get into 4th gear at about 50MPH it feels like fuel starvation as she holds back ( bogging ) and feels like you need to clutch in and rev so deffo an issue.
Once I ease off she goes fine and pulls like a train in 1 2 and 3 im just lacking top end.
Not sure of the jetting and was running fine pre pipe renewal.
Any ideas where to look would be much appreciated
cheers Andie
I can send pics if needed but need to upload as this is the work pc
@safis avatar
@safis avatar
An admin should move this to the NSM side...
PX 125
PX 125
Apologies I didnt realise i had posted on the wrong group. Should I copy and paste this one and re post on the correct one
One of our lovely moderators will be along shortly to attend to you misplaced post.
@mjrally avatar
@mjrally avatar
Someone will move this but until then, can you tell us what jets are installed in your carb? What size is your carb? 20? 24?
PX 125
PX 125
Hi Thanks for the reply. Ive not checked the jet size or carb yet but I know i upgraded when we fitted the kit. Scooter was running fine but then she has sat for a couple of years with no use just the odd start up to keep the engine fresh. I drained the old fuel which had been sitting for a couple of years and thats when I had to replace the oil and fuel line as they were perished. My thinking is,,,,, could the fuel line be too long. I will get the Jet and Carb sizes asap and get back to you but thanks in advance. Ride safe All Scooter emoticon
@fraggleexport avatar
'65 Sprint 177/ '17 GTS300
I suppose with my Sherlock head on you tell us that 'all was running fine before'. For that reason we must look at whats happened in the dormant period... My thoughts;
-Carburettor jets have got gummy...the main jet really
-Your fuel petcock(?) has got crusty at the bottom of the tank and wont allow enough fuel up in the top end of demand
-Has fuel changed over there in the past few years ie more ethanol in the mix?
-Yes , your fuel line being over long is a good shout
Personally Id initially inspect and clean your main jet first. 5 minute job. I dont think its anything to do with the kit
Kevin
PX 125
PX 125
Thank Kevin,
Problem solved it was a schoolboy error.
Went to start her up and she ticked over first click then died.
checked spark great
checked the jets and all shiny and sparkling but gave them a clean anyway
However when checking fuel flow at the Carb was getting a big fat ZERO
I had nipped the pipe when i put the Head Cowling back on so looks like ive had enough on the vaccume to keep her going but once she has sat for a couple of days the pipe has got soft in the hot weather we are having and the place it was nipped was letting nothing through.
Re routed the offending pipe to the outside of the Cowling where it should be and took her for a spin.
Pulling 50MPH in 3rd and up to 60 in 4rth but still plenty of throttle left just not enough road. Not Missing a beat. Happy days
Cheers Guys for the comments
@psma avatar
125 GTR 1977, 50S 1975, GTS 125 Supertech 2021
@psma avatar
Nice you found it!
This is what I found on my just bought small frame, nice work ... Facepalm emoticon
Replaced with standard green fuel line.
PX 125
PX 125
More kink than a cafe in Amsterdam ROFL emoticon
@scooterist avatar
@scooterist avatar
I also made mistakes like that and had similar engine trouble. I removed the tank once and pinched the fuel line with the fuel tank/oil tank. The scooter worked well at lower gears and lower throtle control but would die at full throtle.
Another common problem is the nipple at the carburator, it has to be tighten well, with the proper red waxy paperish seal and a fuel line that fits snug and a good clamp otherwise you get fuel interruption at wide open throtle.
[ Time: 0.0138s ][ Queries: 4 (0.0041s) ][ live ][ 313 ][ ThingOne ]
