@pawel1380 avatar
Vespa Sei Giorni 2022
@pawel1380 avatar
I bought a new Bitubo suspension for my Vespa. I have received the package and found that the entire inside of the box is dirty with oil .. is this normal? anyone had this situation too?
@gtdespatchcourier avatar
GTS 300ie
GTS 300ie
Maybe they sprayed it with light oil when they packaged it to prevent surface rust?
Maybe the seals have failed and it has leaked?
I'd recommend you get in contact with the company.
can't help but thinking that the shock itself is leaking and should be returned under warranty
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
The shouldn't be oil on the packaging. The Bitubos I have seen, all came in clean.
@touring300 avatar
@touring300 avatar
Definitely something wrong, probably a leaking seal. Send it back.
need to Elvis that thing now.
@spdtwn avatar
MP3 250 & Sei Giorni 300 HPE
@spdtwn avatar
Looks like a problem. My recently received Bitubo was clean as a whistle. I agree with other recommendations - send it back.
Made a real difference to the ride, especially with the damping backed right off.
20 GTS Super Tech 300
Upper piston seal can weep a-little self lubricant seal but no that much return it damaged in shipping
[ Time: 0.0122s ][ Queries: 3 (0.0035s) ][ live ][ 313 ][ ThingOne ]
