@zachyzach avatar
@zachyzach avatar
Almost done installing a new wiring harness in a '64 VBB2 restoration. Only challenge so far is the narrow tube that leads to the rear brake at back of the VBB frame. It's super tight -- just a 1/8 of an inch or 3 16ths, etc. So, it's a teeny channel. Barely room for the 3 wires that connect to the brake, much less for the shrink tubing that surrounds the wires.
If I wrap the lot in thin tape, I don't think it will fit through, and the tape will get jammed too.
What have folks done here to get the wires through and keep them in good shape? Strip out the black protective sleeve around the wires and leave them bare? Any other tricks? Just curious if I'm missing any solutions before I remove the protective sleeve. Tks
Just ran into this on my friends 62 Allstate.
My 58 Allstate somehow fits all 3 wires. His wouldn't. So what I did was just grounded the taillight wire under the glovebox cowl bolt. Only have to remove the top one so it's easy. Crimp on a proper fitting then sand under the bolt for an A plus ground. Easy peasy
@chandlerman avatar
Lucky
72 Days Since Last Explosion
Lucky
@chandlerman avatar
I've just stripped the sheathing off when I've had to deal with that, and it's still brutal.
Get ready to cuss a lot.
@zachyzach avatar
@zachyzach avatar
Thanks for the tips. i'll sleep on it and commence the cussing tomorrow.
@chandlerman avatar
Lucky
Lucky
@chandlerman avatar
Run a lead line, then use it to pull the rest through. You may want to lubricate the wires, too, if they don't want to slide through with more than a little persuasion.
And as you're probably already aware, the angle of the tube into the cavity is such that the wire will tend to try and hang on the edge, so you have to hold it up so it doesn't catch.
Oh, and expect to make a blood sacrifice or two while you're doing it. Vintage scooters love blood.
Good luck!
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Run a lead line as suggested then pull some good waxed dental floss through. Wrap dental floss around wires to keep them together and pull dental floss and wiring back through.
1974 Rally 200, 1974 Rally 200 with sidecar, Vespacross bike
Bikes that had the steel guide tube didn't use the sheath. I recommend running an old clutch cable in there to remove any junk that may have built up (rust, old wiring, etc) and then use
a little grease on the wires.
@zachyzach avatar
@zachyzach avatar
Thanks for the knowledge on this bit of frame history. Sounds like congress will not be achieved between the rear sub loom sheath and the narrow brazed on tube from this era. I'll remove a bit more than a foot of the sheath and wires should travel through the tube fine.
[ Time: 0.0134s ][ Queries: 4 (0.0061s) ][ live ][ 313 ][ ThingOne ]
