@kz1000st avatar
@kz1000st avatar
@amateriat avatar
@amateriat avatar
My takeaway: It depends.
@miguel avatar
@miguel avatar
Following amateriat's lead...
My take away: There's massive opportunity for innovation and business.
My career for the last several decades has been solving hard science and engineering problems - really hard. The kind of problems that sound impossible when you start. Where many scientist and engineers are pessimistic about a solution. But given some time to think about potential approaches, putting teams together to find potential viable approaches, we almost always came forward with imaginative and innovative solutions to those "impossible problems". There's always a way. My graduate advisor once said to me, "Miguel, the solution to most problems is crafting the problem onto a similar problem you already know to solve." Brilliant!
Simply defining the problems is 50% of the solution. The article presented a lot of the problem areas, many look quite ripe for new approaches, fresh ideas and innovation. That's the first step to finding solutions.
My advice is don't give up. Solutions to hard problems take time to gestate and take form. Building the solution takes time once you've proven the basic solution. Advances can be slow but they do come.
Have faith. Naysayers never solve problems. Be optimistic. Be part of the solution, not the problem.
Thanks for the article. Pep talk over! Miguel
@coddy avatar
@coddy avatar
Good article, thanks for posting.
Most of it was already known to me but what I didn't realise was just how heavy the HD Livewire battery is at 113KG or 249 LBS. That's not far off twice my weight!
That figure needs to come down significantly and I'm sure it will but sooner the better.
@kimpossible avatar
Tethys - 2012 GTS 300
@kimpossible avatar
Miguel, would you please take on the problem of building a working fusion reactor? Preferable a micro or nano sized one please.
@miguel avatar
@miguel avatar
Hah!! It's an admiral goal and a problem that someone solves but there are so many logistical and regulatory hurdles that I think it will be sometime before we see something that you could power a scooter with!
Miguel
@kimpossible avatar
@kimpossible avatar
Miguel
Really, just show them how to finally get more energy out than they put in. If someone solves the engineering and physics problem, the regulatory hurdles will be stringent, but surmountable. They've been working on this for more than 40 years.
As a librarian, I'm sure that they are going about this backwards. Instead of superheating to plasma to overcome the repelling force of the electron, they just need to turn off the electron for a nanosecond. Then the nuclear force will take over. Yeah, I'm certain that is what they should do. ROFL emoticon
Room temperature nano-fusion, that's all I want.
@miguel avatar
@miguel avatar
A physicist that I worked with once explained the difference between a physicist and engineer. Physicist measure things and the precision and accuracy to which they can measure something is the end goal. Engineers build things to solve problems using physical principles and mostly existing devices. There is, as you expect, a lot of cross over. But in the grand scheme of things, I'm really an engineer at heart and the deep physics associated with room temp fusion is way out of my sweet spot. Thanks for the confidence tho!
Miguel
[ Time: 0.0172s ][ Queries: 3 (0.0073s) ][ live ][ 313 ][ ThingOne ]
