@tunin avatar
Granturismo + gts300
@tunin avatar
Hi guys,
On my GTV 125 the coolant temp sensor wire is missing on top of the engine next to the carb neck. The connector is thereX it looks like is if there was a connector on it, it is a bit scratched… but the cable is nover to be found?
I can not figure out where is is supposed to go to from the diagram to trace it backwards towards the sensor.
Thanx for any pointers.
@tunin avatar
@tunin avatar
I had the engine running and for a while, waiting for the fan to kick in, had it running until 95.2C, it dis not kick in.
Does anyone know when the thermostat clicks the fan… at what temp.?
iirc on my HPE the fan comes on at 105C then turns off again at either 100 or 95, can't remember which. Normal running is 85C.
@tunin avatar
@tunin avatar
Thank you.
I was reluctant to push it that high until I get some research done. I was worried it would boil.
Especially because if the missing cable?
@tunin avatar
@tunin avatar
You were right, I pushed it and at around 103C it kicked in.
I guess the cooling system works ok.
Thank you.
[ Time: 0.0131s ][ Queries: 4 (0.0055s) ][ live ][ 313 ][ ThingOne ]
