2015 Sprint 150
2015 Sprint 150
Hello all new to forum
Have a 14' sprint 150 and I have no brake light when I pull on front lever, but back is no problem so I know it's not a bad bulb, any ideas what can be wrong ?
@touring300 avatar
@touring300 avatar
Have you checked your fuses?
It is the switch behind the brake lever. Open The headset and unscrew the switch to replace.
2015 Sprint 150
2015 Sprint 150
Thanks , that worked. Will be posting my two other problems shortly.
@lebo avatar
@lebo avatar
You didn't mention what worked. & Welcome from the Salt Lake Valley in Utah.
One assumes replacing the brake light switch...
portofino green GTV 300
Welcome to MV from New England
2015 Sprint 150
2015 Sprint 150
Yes , the brake lever switch.
@juan_orhea avatar
S150 '09, Beo 500ie '08
@juan_orhea avatar
Very often a little shot of WD40 or Teflon lubricant will free those little switches up. No tools required.
Sometimes they also get disconnected. Maybe during use, and maybe inadvertently during other projects having nothing to do with the brakes. Not that I would know anything about that, of course.
[ Time: 0.0115s ][ Queries: 3 (0.0057s) ][ live ][ 313 ][ ThingOne ]
