Hi all, I had a full new Px 244 engine built 1690 miles ago with all uprated components and even new casings. I rode faultlessly until this morning, through the gears absolutely no indication of what was to come, pulling up hill in third/ change to 4, transmission dies, engine still running, but no drive. Turned off I can change gears on selector and clutch pulled in makes a difference like it's engaging, kick start acts like the clutch pulled in. There's no crunchy noises, and free wheels ok . Ideas please guys, I'm a bit rusty.
![]() '64 Motovespa 150S (177) , '66 Allstate SF, '65 VBB, '66 180SS
Posts: 1316 Location: S.Salem, NY |
![]() Sun Jun 19, 2022 11:03 am
2007 Stella 225
Posts: 2684 Location: Rochester, Minnesota |
![]() 2007 Stella 225
![]() 1979 P150X, 1983 P200E, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Posts: 3001 Location: Veria, Greece |
![]() Sun Jun 19, 2022 1:12 pm
Lucky
76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate, 08 Stella (for now)
Posts: 5991 Location: Nashville |
Lucky
![]() 76 Sprint V, 63 GL, 62 VBB, 05 Stella, 66 Smallstate, 08 Stella (for now)
Put me down for "it's the clutch," too. In particular, I think you've sheared the woodruff key.
I sheared my woodruff key a few years ago and it was a similar experience. Assuming that's the case, you'll almost certainly need a clutch puller to get it off--the usual two screwdriver method won't work. Then there will be the question of if the crank or cog can be saved. Crimaz make a hardened woodruff key for high output motors, but splined cranks are becoming a thing for a reason. I don't think it's the cogs. Broken gear teeth tend to get caught up in the rest of the gearbox and jam it solid (at a minimum) in my experience. |
