I have finally managed to get the damaged flywheel off and looked at the stator on my VBC 150 8" wheel model: the wires/terminals and coils have seem better days but the points and base plate are ok. The wiring loom is disintegrating too, with that to replace, as well as the flywheel, stator, connection block, brake switch and possibly also the handlebar switch, so it is time to work out a strategy.
I have looed at numerous threads but am still none the wiser. Does the choice boil down to fairly expensive 12v electronic ignition Italian kit (£400) vs cheaper points 12v kit (£100) or cheaper 6v like for like replacement? Or is there any other sensible alternative (I do not fancy winding my own coils or remagnetizing the magneto etc etc - I will have enough on my plate with the loom replacement)
Can any one recommend a reasonably priced comprehensively stator/rotor/fan kit and loom within UK, please? The SIP items are beyond my budget, bike will have light infrequent use but i do want it to start on those times!
Cheers
R
