Mon, 20 Jun 2022 16:22:36 +0000
i was just wondering if anyone knows of any good front racks for a gts that dont require drilling a hole in your front middle cover? thank you
![]() Mon, 20 Jun 2022 16:26:54 +0000
Posts: 11225 Location: Fond du Lac, Wisconsin |
![]() 2007 LX150 2015 GTS 2013 BV 350
Pretty sure mine is a FACO, no drilling required! Mounts pretty easily as well. Don't use it very often, so nice to be able to remove when I want to.
Mon, 20 Jun 2022 21:35:40 +0000
awesome! do you have a link to what it looks like or to buy? im having trouble seeing which ones require drilling and which dont. and the descriptions for them dont mention either. thank you!
![]() Mon, 20 Jun 2022 22:53:05 +0000
2010 GTV250ie - Sienna Ivory, BMW F650CS, HD 883 Sportster
Posts: 1011 Location: North Coast - Rural |
![]() 2010 GTV250ie - Sienna Ivory, BMW F650CS, HD 883 Sportster
Scooterwest "search" function is good. Pick of brand/model/style. Here is a quick example of a front rack, without drilling using the Scooterwest "search" function:
VESPA GT GTS CHROME FRONT RACK BY FACO (GT/GTS/GTV) There are many flavors to be had. I see they have black, as well. Not sure about matte. Hope this helps? Best to you! |
![]() GT 2.4
Posts: 8004 Location: NWAOK |
Tue, 21 Jun 2022 01:35:48 +0000
FACO, FA Italia, Cuppini, and if you can think of another company that makes front racks for the GTS, probably theirs too.
![]() 2021 GTS 300 HPE +2013 GTS 300ie + 294 Polini
Posts: 1952 Location: Pretoria, South Africa |
Tue, 21 Jun 2022 05:54:19 +0000
I have a FA front rack for Sunny like this:
https://www.sip-scootershop.com/en/product/luggage-carrier-front-fa_FA00110 Mine has a metal strap that secures the bottom to the bodywork at the front fender cutaway. I lined that strap with thin neoprene to prevent scratching. That meant I had to use a slightly longer screw to reach the carrier. Because front racks are made to fit both GTS and GTV scoots, they sit high on the front. I would have preferred them to sit a little lower, but it means you can also strap stuff below the rack if you have clear space and don't obscure the turn signals. That space is ideal for a tool roll with your puncture repair kit when the underseat storage is full of other stuff. |
![]() Tue, 21 Jun 2022 06:10:23 +0000
GTS 300ie Touring 2013 - Signora D'argento & GTS 300ie HPE 2022 - Regina Arancione.
Posts: 2047 Location: Lancaster, U.K. |
![]() GTS 300ie Touring 2013 - Signora D'argento & GTS 300ie HPE 2022 - Regina Arancione.
The quality of chrome differs considerably between manufacturers. The cheaper ones will start to pitt and show signs of rust very quickly. Whichever one you choose, try to regularly apply a coating of wax or light lubricating oil especially in damp/wet weather.
Positive
![]() Tue, 21 Jun 2022 11:12:42 +0000
GTS super 300
Posts: 332 Location: Montreal Canada |
![]() GTS super 300
Fudmucker wrote: I have a FA front rack for Sunny like this: https://www.sip-scootershop.com/en/product/luggage-carrier-front-fa_FA00110 Mine has a metal strap that secures the bottom to the bodywork at the front fender cutaway. I lined that strap with thin neoprene to prevent scratching. That meant I had to use a slightly longer screw to reach the carrier. Because front racks are made to fit both GTS and GTV scoots, they sit high on the front. I would have preferred them to sit a little lower, but it means you can also strap stuff below the rack if you have clear space and don't obscure the turn signals. That space is ideal for a tool roll with your puncture repair kit when the underseat storage is full of other stuff. Last edited by Spirovision on Thu, 23 Jun 2022 01:36:19 +0000; edited 3 times |
![]() Vespa Super 300
Posts: 1820 Location: AZ |
Wed, 22 Jun 2022 01:28:48 +0000
i have a front rack which comes with protective bars on the front, believe it is Faco and believe i bought it from Scooterwest and is great, if more info is needed i can look a bit more where and when i bought it
![]() Thu, 23 Jun 2022 01:36:00 +0000
GTS super 300
![]() GTS super 300
RE FA front rack, can anyone please show a photo of the rack attached? I purchased the same one but the top hooks seem to rub against the headlight cover ?? and would love to see the position of the bottom metal strap once attached thank you
Fri, 24 Jun 2022 21:19:33 +0000
Hope this pic helps, as the temp in AZ is so high the Vespa is off to the side as not being ridden now, and hope I attached the pic properly
Sat, 25 Jun 2022 17:34:13 +0000
Spirovision wrote: RE FA front rack, can anyone please show a photo of the rack attached? I purchased the same one but the top hooks seem to rub against the headlight cover ?? and would love to see the position of the bottom metal strap once attached thank you ![]() |
![]() Sat, 25 Jun 2022 18:16:28 +0000
Posts: 22149 Location: Harriman, Tennessee, Tn |
![]() Neutrino MP3 492.7 AK, 2013 Moto Guzzi Norge
Hummus2 wrote: i was just wondering if anyone knows of any good front racks for a gts that dont require drilling a hole in your front middle cover? thank you |
![]() Sat, 25 Jun 2022 18:24:12 +0000
old as dirt wrote: never seen one that does. |
![]() Sat, 25 Jun 2022 19:50:57 +0000
GTS super 300
![]() GTS super 300
Fudmucker wrote: Here's Sunny with front rack fitted. |
![]() 2007 250 GTS, 1980 P200E, 2010 ThunderFly 190 (SOLD) 2015 Yamaha SMax
Posts: 3214 Location: Springboro, OH |
Mon, 27 Jun 2022 14:27:09 +0000
I've had the Faco no drill rack for several years and it is well made and sturdy. I placed clear vinyl paint protection film at all the contact point to prevent paint damage at those places.
The chrome does require some attention a few times a year to keep rust at bay, but that is true of all chrome. 10 minutes with Never-Dull wadding polish does the job. As noted above, there are other options, but I have no personal experience with those. ![]() Beer Run at Amerivespa... |
![]() Mon, 27 Jun 2022 21:57:26 +0000
'04 Genuine Stella, '03 Vespa ET, '62 Motovespa 150S (with a P125X engine), a '71 Rally 180, '57 Lambretta LD125 Mk. III
Posts: 478 Location: Lehi, UT Utah |
![]() '04 Genuine Stella, '03 Vespa ET, '62 Motovespa 150S (with a P125X engine), a '71 Rally 180, '57 Lambretta LD125 Mk. III
It will also depend on which horn cover you have, I have a 2021 GTS 300 hpe, and the horn cover goes all of the way down the front. If you have a horn cover that only goes partway down then you would be able to use the "strap" style front rack.
Mine is this style. https://i0.wp.com/vespaportland.com/wp-content/uploads/2014/10/GTS-300-Verde-Relax-1-scaled.jpg?fit=1024%2C731&ssl=1 |
