Tue, 21 Jun 2022 17:54:35 +0000
Mine arrived at the San Francisco dealer June 18th, 2022.
Positive
2019 MP3 500 Sport
Posts: 209 Location: California |
Wed, 22 Jun 2022 03:06:20 +0000
2016 Mp3 500ie Sport
Posts: 165 Location: California |
Welcome to the club!
The Mp3 may not be the fastest bike out there but its a beast in the twisters and plenty of cargo. This form is full of mods and info including * LED headlights * EVAP Canister removal * Tires and wheels * Break-Fix * So much more. If you have a question just check the forums as someone has probably already answered it and if not then we're a helpful bunch and support eachother. |
mp3 500 2018 (USA-version)
Posts: 60 Location: Belarus, Minsk |
Wed, 22 Jun 2022 12:18:20 +0000
Congratulations. Sorry for the indiscreet question..... what is the cost*?
Wed, 22 Jun 2022 14:03:39 +0000
I can't wait to pick it up. Price was as advertised - $9,999 US for the Advanced model. Can't wait to pick it up on Friday.
2015 MP3 500 ie Business
Posts: 960 Location: Belgium |
Wed, 22 Jun 2022 15:35:11 +0000
Get the extended factory warranty (4 years total) prior to you driving it off the showroom floor.
The extra cost of the warranty can easily pay for itself. |
Wed, 22 Jun 2022 22:46:42 +0000
Yes, i did get the extended warranty (3 years offered); so I am covered for 5 years.
![]() 2007 MP3 250ie / 2022 MP3 500HPE SA
Posts: 58 Location: CCS-Vzla |
Fri, 24 Jun 2022 20:56:42 +0000
dariusz wrote: The 2022 comes with a tools bag as previous MP3? |
Fri, 24 Jun 2022 21:03:02 +0000
sbaert wrote: They always have, so the answer is yes. Are you sure? My 2007 come with, but I read in some part that the post 2020 don't come with tools, only with the one to adjust the shock absorbers |
Fri, 24 Jun 2022 23:19:35 +0000
Piaggo Tool Kit C-Spanner Sources
The only really valuable thing in the tool-kit is the C-Spanner that is bent 90 degrees. This allows you to adjust the suspension spring that is otherwise covered by the exhaust. Without this tool you would have to remove the exhaust in order to access and adjust the spring tension. The rest of the toolkit is a mix of #15 and #20 (#25?) torx drives, a fixed crescent wrench, and a spark-plug / tire-lug tool. Most everything else in the tool-kit can be done with regular off the shelf hardware store tools (in metric) The tool kit I carry with me on most trips is extensive as I like to be able to self-rescue. I can list it all out here if you want but really you have to tailor it a bit for what and where you ride.
Positive
![]() 2020 MP3 500 HPE Sport ABS/ASR
Posts: 4507 Location: El Pueblo de Nuestra Señora Reina de los Ángeles sobre el Río Porciúncula |
Sat, 25 Jun 2022 00:26:15 +0000
dariusz wrote: Hi, thanks for the answer. Are you sure? My 2007 come with, but I read in some part that the post 2020 don't come with tools, only with the one to adjust the shock absorbers |
2019 MP3 500 Sport
Sat, 25 Jun 2022 02:36:52 +0000
I bought used so I guess previous owner kept the tool bag 😝
I have my own anyhow |
Sat, 25 Jun 2022 18:58:25 +0000
mimi8989 wrote: Sadly, my 2022 did not come with a tool bag. |
Tue, 28 Jun 2022 15:44:43 +0000
MP3 500 HPE 2019
Posts: 67 |
My second hand 2020 just came with the shock spanner, make sure you get the dealer to check the front brake lever does not touch the windshield, some are still coming like that
Tue, 28 Jun 2022 18:14:31 +0000
Wrong
Tue, 28 Jun 2022 20:21:11 +0000
MP3 500 HPE 2019
Posts: 67 |
I to have a bad habit also of carrying half my workshop tools for nothing
![]() pinheadh78 wrote: Piaggo Tool Kit C-Spanner Sources The only really valuable thing in the tool-kit is the C-Spanner that is bent 90 degrees. This allows you to adjust the suspension spring that is otherwise covered by the exhaust. Without this tool you would have to remove the exhaust in order to access and adjust the spring tension. The rest of the toolkit is a mix of #15 and #20 (#25?) torx drives, a fixed crescent wrench, and a spark-plug / tire-lug tool. Most everything else in the tool-kit can be done with regular off the shelf hardware store tools (in metric) The tool kit I carry with me on most trips is extensive as I like to be able to self-rescue. I can list it all out here if you want but really you have to tailor it a bit for what and where you ride. |
![]() 2020 Liberty 150, 2020 MP3-500
Posts: 507 Location: Reno |
Wed, 29 Jun 2022 01:47:49 +0000
The tools are hiding under the mat in the pet carrier
The shock tool will help you take off the gas cap, a small dab of never sieze on the threads helps The original owner of mine removed the strainer from the gas tank inlet, I think it makes it easier to fill, still far too easy to make a gas splash when filling Drill out the rivets for the evap, clip the hoses Start it put you finger over each hose, plug the one with vacuum, shove the open one out of the pet carrier so the fumes vent between the panels To increase trunk space |
Fri, 01 Jul 2022 02:52:02 +0000
mpfrank wrote: My 2020 does not have a tool kit. I'm not even sure that it has the shock adjuster. ![]() Yep. Looked under the mat. There it is. |
Sat, 02 Jul 2022 01:18:01 +0000
Mine 2022 comes with the clear also, and I don't like it
Is a way to purchase a tinted windshield? Or use some tint wrap (as for the car windows) a not to much dark? Someone do it with good results? |
