Hi to you all.
I am new to Vespas and have recently bought a 2003 GT200 which is completely standard with 5574 km from new. I want to change the rear tyre but need to remove the exhaust first. My exhaust is standard with the flange at the top which fits to the exhaust studs. My question is: What size are the exhaust studs and nuts? A 10mm spanner is too loose, but a 9mm spanner will not fit over the nut. Is there a special vespa tool? Were the exhaust nuts copper covered when new? I realise that if I break a stud it will mean an awful amount of work, so I have been spraying Plus Gas on the area each night for a week, but do not want to try and undo until I have the correct tool. Thank you for your anticipated informations.
