SUDDEN LOSS OF ALL ELECTRIC POWER- VESPA GT200
I've had my 2008 Vespa GT 200 several years. I ride it daily, keep it garaged, in great shape, and it has been totally reliable.
Problem: After a 40 km drive today with several stops, I went into a store for 10 minutes. When I exited the store, I popped open the Vespa's seat using the seat button switch, so the scooter still had electrical power at that point. But after I put the seat back down, turned on the key and attempted to start up the scooter, it had no electrical power whatsoever- the dashboard and headlamp didn't light up, the seat no longer actuated with the electrical button, nothing electrical worked. The scooter's been in daily use. The battery's been strong and gave no prior sign of any problem.
Do you have any idea what could have suddenly severed all of the scooter's electrical power when the key is turned on? Is there a major in-line fuse that could cause this? (All of the fuses in the glovebox fuse panel look good) A failure of the ignition switch? A major electrical connection that suddenly disconnected, shorted out, or otherwise failed? Could the battery have suddenly died?
I'd greatly appreciate if anyone out there can help shed some light on this (no pun intended).
