Since i'm building a fresh engine, I'm starting off with a 60 stroke crank. Since the cases have reed valve intake, I have a bit of a challenge on choosing a crank. Possibilities are full circle, bell-type or just regular disc valve models. I'm looking for information on what would be a good one or are there some cranks to avoid?
Malossi's own crankshaft - I'm a bit put off by the price of 588eur
https://www.sip-scootershop.com/en/product/full-circle-crankshaft-malossi_53161760
Mazzucchelli full circle - much more affordable at 265eur
https://www.sip-scootershop.com/en/product/full-circle-crankshaft-mazzucchelli_45040000
Mazzucchelli bell - is this weaker than the full circle one?
https://www.sip-scootershop.com/en/product/bell-shaped-crankshaft-mazzucchelli_45041000
Sip Premium rotary - any downsides on running a rotary crank?
https://www.sip-scootershop.com/en/product/long-stroke-crankshaft-sip-premium_45021510
DRT rotary - DRT products have been always nice in my experience
https://www.sip-scootershop.com/en/product/long-stroke-crankshaft-drt-sip-vnox-gt_45047000
Or should I go straight with 62 stroke Uncle Tom bell? I've read that the cases have to be machined to remove rotary pad, but Malossi cases do not have this to begin with. Could this be a straight fit without machining the cases?
https://www.sip-scootershop.com/en/product/bell-shaped-crankshaft-sip-premium-uncle-tom_45022500
