@shepys avatar
Vespa T5 classic 1994 and 1980 Vespa p200e
@shepys avatar
Hi guys I had my carb on to clean and the air screw was set too 1 1/2. I read it's 2 1/2. Do I put it back to 1 1/2 or set it to 2 1/2
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
is it stock, and is the carb a dell'orto or a "spaco" dell'orto?
As far as I am aware the stock setting is 1.5 on the T5, like for the other P series - but the finer threaded spacos should be 2.5 stock.
That being said, it's really about what runs best on your scoot - the difference between 1.5 and 2.5 is relatively modest and you can find which side of that range your idle and takeoff are smoothest
@shepys avatar
@shepys avatar
Yes Its a stock T5. I will set it to 1.5. Thank you for the help
[ Time: 0.0095s ][ Queries: 3 (0.0024s) ][ live ][ 313 ][ ThingOne ]
