Thu, 23 Jun 2022 17:56:55 +0000
2006 Vespa LX150
2006 Vespa LX150
Thu, 23 Jun 2022 17:56:55 +0000 quote
Hello all,
I would like to change the oil of my LX150 in one of the next weekends (definitely overdue in terms of time).
The Piaggio original part # is 82635R. I am open to use an equivalent part from different manufacturer (Wix, STP, K&N...) that I can find at a local auto parts store and I would like to use the expertise in the forum before starting the work.
My assumption is that pretty much any filter with the same thread (should be M14) and similar dimensions (diam 52 x height 61 mm) should do its work just fine. Do you agree?
In case, has anyone some indications on equivalent filters from various manufacturers that can be used to replace the original 82635R?
Thank you!
Thu, 23 Jun 2022 18:29:57 +0000
2007 GT200, 2008 Yamaha C3
Thu, 23 Jun 2022 19:07:35 +0000
Thu, 23 Jun 2022 19:07:35 +0000 quote
Abner_Bjorn wrote:
HF197, ask for it by name. It has a 17mm hex built on the end.
Agree, HF197. The HF stands for HiFlo.
Fri, 24 Jun 2022 00:48:48 +0000
2006 Vespa LX150
2006 Vespa LX150
Fri, 24 Jun 2022 00:48:48 +0000 quote
Thank you gentlemen, order submitted!
Fri, 24 Jun 2022 03:29:23 +0000
GT 2.4
GT 2.4
Fri, 24 Jun 2022 03:29:23 +0000 quote
https://www.scooterworks.com/Oil-Filter-Genuine-Vespa
Using cheap filters makes your Vespa sad. The OEM filter by Mahle is (barely) less than $7.
https://scooterpartsco.com/ricambi/030-piaggio/piaggio-oil-filter-for-vespa-piaggio-aprilia
I'm seriously curious why anyone would pay more for a cheap aftermarket filter than a real OEM filter. Malossi, K&N, I get. But Hiflo or some weird brand like Power Lizard from AliExpress? What's the reasoning? If they were free vs $10 for the real thing, most Vespisti will pony up the $10.
Fri, 24 Jun 2022 05:13:52 +0000
Fri, 24 Jun 2022 05:13:52 +0000 quote
So, you think we should all use OEM motor oil also? And OEM coolant? And OEM brake fluid?
Fri, 24 Jun 2022 14:29:09 +0000
Fri, 24 Jun 2022 14:29:09 +0000 quote
Yep George, you know more than the rest of the world:
Fri, 24 Jun 2022 22:13:30 +0000
GT 2.4
GT 2.4
Fri, 24 Jun 2022 22:13:30 +0000 quote
I definitely know more than one person in Colorado who likes Youtube, and everyone else who disagrees with me.
But everyone who agrees with me probably knows as much as I do, and they're pretty smart people.
Sat, 25 Jun 2022 03:32:05 +0000
2012 LX150ie
2012 LX150ie
Sat, 25 Jun 2022 03:32:05 +0000 quote
+1 for 'Vespisti'. A new word for me.
  DoubleGood Design
[ Time: 0.0252s ][ Queries: 4 (0.0045s) ][ Debug on ][ 277 ][ Thing Two ]
