@zachyzach avatar
@zachyzach avatar
I should have taken the NSM bot's advice and just started a new thread. So here goes.
Since most discussions on air filter "heart" drilling for tuning purposes are pretty old -- and views were hotly contested back then! -- I'd love to know, what are folks' newer experiences?:
Question is, whether to drill out a 5mm hole in the heart cutout of the air filter on a stock dell'orto SI 20/20D as recommended by Pinasco for its iron 177cc 2-port kit (to open up air flow above the main jet stack).
I rebuilt a 1964 VBB2 motor, added the Pinasco top end, using the aforementioned 20/20 carb and will run a Malossi Power Classic big box exhaust. I have a supply of main jets up to 110, tho I'm missing a 108 size currently.
Anyone have recent experience, good or bad? Did it screw up the jetting as some previously reported? I don't have lots of tuning experience And I have only one original air filter.
⚠️ Last edited by zachyzach on UTC; edited 1 time
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Question is, whether to drill out a 5mm hole in the heart cutout of the air filter on a stock dell'orto SI 20/20D as recommended by Pinasco for its iron 177cc 2-port iron kit (to open up air flow above the main jet stack).
I say chuck the entire filter and put one of these on, bypasses entire drill or not to drill debate. When I can go from rich to lean by removing a filter it's a choke point for performance.
https://www.shapeways.com/product/ZFBJ7HCAE/20mm-largeframe-vespa?optionId=451888&li=marketplace
If I had to vote "drill", that filter is setup for a standard cylinder and exhaust that was about 8hp. .
@zachyzach avatar
@zachyzach avatar
Thanks for pointing that out.
As far as drilling out the filter, what have I got to lose.
A small amount of aluminum?
[ Time: 0.0124s ][ Queries: 4 (0.0038s) ][ live ][ 313 ][ ThingOne ]
