@norman avatar
1978 MotoVespa 160GT, 2009 LML Star 2T (Stella), 1961 Lambretta S2
@norman avatar
I need to replace the damper on my Motovespa 160GT. One thing I've noticed is that the new damper has the standard Italian tabs on the lower mounting, whereas the Spanish swing arm doesn't have corresponding slots.
My dilemma is whether to keep the scooter original and grind off the tabs on the shock, or cut slots in the original swing arm. What is the purpose of the locating tabs, and why did they remove them on Spanish models?
Any advice greatly appreciated before I break out the Dremel!
@finyoshi avatar
@finyoshi avatar
You don't want metal-on-metal rubbing there or the shock bushing to turn open the nut attaching the shock. Tabs keep the shock bushing always in same position along the fork and bolt.
When shock is going up and down, the rubber is flexing instead of metals rubbing.
@norman avatar
@norman avatar
That makes sense, but I keep asking myself why didn't the engineers make the swing arm with slots in the first place? Surely there's a reason they didn't do it ...
@safis avatar
@safis avatar
Is there a chance your old shock had some kind of bearing?? I would slot the swing arm since all shocks come with the tubs...
@moto64 avatar
@moto64 avatar
I just checked my '64 150S and it appears to be the original shock without the tabs and it's firmly in place. I think that having the inner bushing de-tabbed and clamped hard against the boss would fine. Or cut the slots with a Dremel. Maybe someone can provide the orientation.
The only place I have seen a shock bushing keyed to the mount is on a Vespa but the swing arm does move through more of an arc than most cases.
@norman avatar
@norman avatar
Thanks guys, I think I'll cut the slots in the swing arm. Fingers crossed!
[ Time: 0.0170s ][ Queries: 4 (0.0062s) ][ live ][ 313 ][ ThingOne ]
