From what I read here and in some French forums (and please confirm if I'm true) to gain some "happiness", smooth and reliable response, without losing high speed and without adverse effects, the best that I can do is:
- Change the roller weights and put a staggered config (25-21-25-21-25-21-25-21). In my case in the MP3 250 the DR.P are good but not that good, so I stay with the OEM ones.
- Change the clutch springs to Malossi yellow ones (when the time is right and wear and tear warrants it, I think in change the whole clutch by a Malossi Maxi Fly with the Malossi Bell)
- Change the variator spring to Malossi White or Yellow (in France all people talk about white, not sure between them what is the better choice?)
- Increase the gap in the variator 0.5mm. Something like the Fuzzy washer, but making a washer that replaces the original (2mm) one with a 2.5mm. (Less parts, more direct)
Any else that I'm missing?
Thanks for the help and advice, regards
