p125e
p125e
I have a polini 177 kit on a PX125E
need help with jetting here, Im more used to lammys
polini177
tm32
rd350 reed
mazz cut crank
sip jl lefty
im thinking to start around 220 main and 25 pilot with needle clip in the middle
also running a mikuni pump do I need to change the needle and seat ?
Cheers
Vic
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
polini177
tm32
rd350 reed
mazz cut crank
sip jl lefty
Cheers
Vic
I have a TM30 on a Pinasco 225
Watch out with what you use for an air filter, I was using a ram air filter and found out it was a restriction and changed my entire setup for needle jet and jet needle when I removed filter and connected bellow from frame to carburetor. Went really lean on bottom half of throttle.
Main jet is a 260
I've been experimenting with 25 and 27.5 pilot jets.
I haven't actually needed a fuel pump for normal use yet. I want to install a larger fuel tank which would put reserve fuel below carburetor fuel inlet.
Needle and seat depends on fuel pump pressure. I've been experimenting with one recommended here by another user. About the same pressure as a few feet of head pressure from gasoline. Could realistically be the same as a dirt bike with a full tank of fuel filled to top gravity feeding a carburetor.
0.05 bar (0.725 psi) to 0.1 bar (1.45 psi) - fuel pump rated operating pressure range.
1 foot of head pressure = 0.43 PSI
2 foot = 0.86 psi
3 foot = 1.3 psi
https://www.accelerationkarting.com/dellortofuelpump.html
⚠️ Last edited by Christopher_55934 on UTC; edited 1 time
p125e
p125e
Thanks Chris, I might start with a higher main
[ Time: 0.0097s ][ Queries: 3 (0.0014s) ][ live ][ 313 ][ ThingOne ]
