@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Searching online, I can find that oil drain and fill plugs are an M8, not finding thread pitch. I want to chase threads of holes and plugs to clean them up.
They are Gran Sport plugs
Magnetic drain plug in drain hole starts about 25% of the time, it's hard to get started, once you get it started it'll tighten up using your fingers.
Magnetic drain plug in fill hole starts easily.
The fill hole plug goes starts in both holes easily.
Anyway hoping I can clean up threads and take care of annoyance.
⚠️ Last edited by Christopher_55934 on UTC; edited 1 time
VNB VSC VMA VSX - o9c vbc vmb
I*think* (90% certain) 1.25 but I am not at home to measure and confirm.
2007 Stella 225
2007 Stella 225
Measured both drain plugs they are M8x1.25 threads. Purchased a made in Japan tap and die as they were the best Northern Tool had. None of the threads made me ask "Why am I doing this?", drain plug with magnet was worst offender and I wondered if I was cross threading it into die. I wasn't and in the end you can now thread magnetic drain plug by hand until its gasket seats.
I can't recommend Gran Sport brand magnetic drain plugs. Something as simple as that plug just cost me $16.36 (plugs) + $18.00 (tap&die)+ $6.50 (gas)+ 2 hours of my life, figuring out threads on drain plug just weren't cut correctly.
parallelogramerist
parallelogramerist
Each and every single time I split the cases on any of my engines, I automatically install a Time-Sert into the drain plug hole (whether it's needed or not). I've exclusively used the G.S. magnetic plugs in all of my cases (something like 12 different cases). I've have zero issues with the GS brand oil plugs. They come as a paired set, but only one of the plugs has a magnet in it.
I did buy the $5 SIP brand magnetic oil plug...only once. SIP uses a VERY weak magnetic. So weak it is, that the oil drain plug won't actually stick to steel!
I haven't used the BGM magnetic plugs yet, but they looks to be very nice quality. From the pictures, it appears that the pair of plug both have a magnet in them? If that the case, then they're twice the deal cost wise, when compared to the GS brand.
⚠️ Last edited by whodatschrome on UTC; edited 1 time
2007 Stella 225
2007 Stella 225
I did buy the $5 SIP brand magnetic oil plug...only once. SIP uses a VERY weak magnetic. So weak it is, that the oil drain plug won't actually still to steel!
I must have had bad luck with mine from Gran Sport.
parallelogramerist
parallelogramerist
I just found an old pic on my phone of a Grand Sport vs a SIP magnetic oil drain plug. The GS plug is the one on the right that actually works. The SIP magnet isn't even strong enough to stick to clean metal!
2007 Stella 225
2007 Stella 225
Gran sport must use a neodymium magnet or something similar. Mine was is strong also. Good to know about staying away from SIP version.
[ Time: 0.0124s ][ Queries: 4 (0.0043s) ][ live ][ 313 ][ ThingOne ]
