Gts 300 notte
Gts 300 notte
hello! these HPE's suck up alot of oil on long road trips, just wondering if those red MSR bottles are ok to store extra oil in them. thanks!
They'll be fine - they hold gasoline quite happily after all!
@touring300 avatar
@touring300 avatar
Just don't forget your funnel!
Or your towel!
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
You could also carry an oil bottle. 😃
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
Do they really burn that much in between oil changes?
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
Enough that you should have access to oil if you ride at highway speeds for an extended time. I wouldn't say it's much all things considered, but important to stay on top of it nonetheless.
That's an old question that has been thrashed out. Conclusion is generally if an hpe is ridden hard and long then it drinks.
If the road trip is say 2000km then topping up before and after the trip is fine. If doing 4000km then should taking some oil.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
I've always carried my extra oil in the plastic container it's sold in. Never had an issue of any kind with that practice.
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
I love Vespa's commitment to all things retro. I've owned dozens of motorcycles and scooters but none that were made after 1985 drank oil. Piaggio fully committed
if you google ktm oil consumption you'll see many people discussing similar. I know my brother with his ktm has said it drinks a bit unlike his previous bikes.
@cheshire avatar
GTS (sold)
@cheshire avatar
GTS (sold)
As I understand it, the point of fuel containers is because petroleum at certain levels of refining will react with some common bottle materials. Fuel is (IIRC) the most caustic/reactive, so if it's good for fuel, I'd trust it for oil. MSR bottles are aluminum, so definitely good for the job, as long as you don't puncture it or forget to screw the lid back on.
@touring300 avatar
@touring300 avatar
Unless you are doing the Cannonball, using a MSR bottle is perhaps a bit of a waste. The smallest bottle appears to be 325 ml or 11 fL. oz. If you need to top-up on a long journey, chances are you will only need to add 100~150 ml to get the oil back to the correct level.
[ Time: 0.0145s ][ Queries: 3 (0.0055s) ][ live ][ 313 ][ ThingOne ]
