@j_scott avatar
2018 GTS 300
@j_scott avatar
2018 GTS 300
As i was taking the black cover off to get to the upper mount of the rear shocks. I noticed that this black vent tube is snapped off. Either i did this by taking off the black cover or it broke off on its own? I do notice that the vent was working previously when i filled the neck to the top with gas and it drained. But i do recollect that last time i filled up it wasnt draining to the bottom. I didnt think anything of it.
Question is, how in the world do i fix this? Epoxy putty?
I wonder if heat can do this. It does sit in the open a couple times in the sun for 8 hours when my wife takes it. There is no shade
I have disconnected the evap a while ago, so there is a long tube that routes down below to the ground to vent.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
I'd go with the epoxy fix you mentioned. That should do the trick. Just make sure the vent hole is not accidentally blocked off by excess epoxy during the repair.
@j_scott avatar
2018 GTS 300
@j_scott avatar
2018 GTS 300
I think thats what I'll do. So odd, that should take some force to snap that off like that. Thanks, i was thinking that should do it.
2020 primavera 150
2020 primavera 150
I believe I would take a small piece of copper tubing and then use JB Weld that way you would not block the hole.
If it's ABS (I don't know...), then ABS solvent glue is by far the best solution, otherwise JB Weld should be able to do the job.
@abner_bjorn avatar
@abner_bjorn avatar
Likely to be HDPE. It's under no pressure. JB Weld in a 3/16 brass nipple.
@j_scott avatar
2018 GTS 300
@j_scott avatar
2018 GTS 300
I agree putting a copper tube in while gluing it up. That will help keep it open. I forgot there is a JB weld option. ABS solvent glue could work if it is ABS. Im not sure either.
Thanks for all the input
2020 primavera 150
2020 primavera 150
That nipple would probably work good
it ain't gonna be 'cause of spending time in the sun. many Vespas spend a long time in the sun and I've never heard of this happening. especially for a 2018 scoot
@j_scott avatar
2018 GTS 300
@j_scott avatar
2018 GTS 300
I think it could. But i think it may be too long. I would cut it in half or a section off of the barbed side then glue it in.
@j_scott avatar
2018 GTS 300
@j_scott avatar
2018 GTS 300
Now that i think of it, it sounds silly lol
[ Time: 0.0147s ][ Queries: 4 (0.0050s) ][ live ][ 313 ][ ThingOne ]
