2021 Primavera 150 75th
I wont' get into the backstory, but my local dealer and I won't do work together. As such, for simple things like oil changes and wheel maintenance I want to do it myself. FOr warranty work i will trailer it 3 hours to the next dealer.
What lifts do people use for their Vespa's and why? I'm in Canada so I want something readily available up here.
Thanks!
@shebalba avatar
@shebalba avatar
I think a lot of folks use the Harbor Freight lift. Not sure if this can be easily obtained in Canada.
I built one (and I'm by no means Bob Vila) based on a few different plans I saw on the interwebs.
I went overboard with the wheel chock, and had to buy a ramp, both have come in handy for other purposes... but otherwise it was fairly inexpensive.
What I like about the table is the under storage. I can also just stand it up when not in use if I need to reduce it's footprint in my garage. I could have made it lower and smaller, but this is what I ended up with.
I added casters which came in handy when needing to rotate for better lighting or if I wanted to start/run it outside.
Right now I'm using it as a coffee bar in attempts to perfect espresso.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
I use an air operated table lift from Pro Cycle. It's been a back saver for me. I chose the Pro Cycle because I work on everything from Scooters to heavy motorcycles. It lowers to about 6" off the floor and has a ramp to make loading easy. When raised, it will go as high as about 32" (table height). I've been using this lift for about 15 years and I've had absolutely no issues with the lifting mechanism or the wheel vise. I just lube the pneumatic cylinder every couple years.
Racing Sixties 300, Cub, Gold Wing, Can Am
I use a Kendon stand up lift table, air powered. Since it's narrow I made two wing tables so I could ride large touring motorcycles onto it.
If I was only looking to service a scooter I too would build a table. Because I like working from a roller stool mine would be about half the height of Shebalba's but the basic construction would be the same.If building a table determine height based on your own height and working style.
@adri avatar
Atypical Canadian
Atypical Canadian
@adri avatar
I used a Harbor Freight one, easy for me to get because I just borrowed a truck and drove to Niagara Falls from Toronto. Bit more of a mission for you in Edmonton.
Here's a link about how I customized it: https://youmotorcycle.com/diy-motorcycle-table-lift-side-extensions.html
Then I upgraded to a Black Widow Pro Extra Wide Motorcycle lift. Truthfully, it's overkill for a scooter, but she's wide enough that I can also use it for servicing my snow blower, the extended family's ATVs, and other toys, etc. I even got the front extension for it so it can fit choppers.
This lift: https://bit.ly/3yadY8z
However, if you don't need the extra wide size, in other words, this is strictly for light motorcycles you can push up easily, for almost 1/3rd the price you can get the base model: https://bit.ly/3nyAHpU
I'm a clumsy worker and have spilled DOT4 brake fluid on this lift probably a dozen times, it's kind of absurd how well it's held up. Just spray a little Goo-Gone and wipe and the thing always looks new.
Zero maintenance or issues in 4+ years of ownership so far.
@papagirl avatar
'21 Vespa Sprint 50
@papagirl avatar
'21 Vespa Sprint 50
Alberta Cycle I assume?
Thanks!
@aiosi avatar
@aiosi avatar
+1 on the Kendon lift.
It's nice to have height adjustability when you're working on something like the rear shock - going back and forth from above to below.
It does have a handle to pump it up if you don't want to fire up the compressor in the middle of the night and wake the neighbors.
[ Time: 0.0113s ][ Queries: 4 (0.0025s) ][ live ][ 313 ][ ThingOne ]
