pinheadh78 wrote:
Check the parts diagrams for Electrical systems and body work on Parts Piaggio and EZ parts. It should show up and you can get the part number from there. Just make sure you know both model year and the sub-variant you have. though similar there can be some significant differences between EU, US, other versions.
I find a possible part number, but like to be sure before order it. Part number: 1D002789??
pinheadh78 wrote:
Why disable the DRL? I'm genuinely curious if its something like increasing stealth in unpleasant areas or the bright DRL is blinding others.
That would make you much harder for cars to spot you coming which would increase the probability of a car pulling out in front of you.
Think smidsy weave when approaching intersections. Without a bright DRL you would be near invisible. I personally chose the brightest LED bulb I could get because if it greatly increased my chances of been scene.
If its about power usage there are a few threads on LED lights that free up the amps for other usage.
It don't disable the DRL, it disable the low beans as you are in day, exactly as EU motorcycles. You have DRL, low beans and high beans. I don't like to have the low beans all day long on.
