Getting close to brake line for disc brake on right. Could push it back a bit further.
![]() Fri, 08 Jul 2022 22:16:16 +0000
2007 Stella 225
Posts: 3237 Location: Rochester, Minnesota |
![]() 2007 Stella 225
Anyone have pictures of how you aligned yours to body? Pushed it back as close to light as I could and tried lining up top curve of plastic with headlight.
Getting close to brake line for disc brake on right. Could push it back a bit further. ![]() ![]() ![]() ![]() |
![]() 1979 P150X, 1983 P200E, 1988 T5, 1995 PX200E, 2011 Yamaha Fazer 600 S2
Posts: 3452 Location: Veria, Greece |
Sat, 09 Jul 2022 02:06:39 +0000
Malossi shows the brackets mounted the other way around on their site…
![]() Sat, 09 Jul 2022 11:46:40 +0000
2007 Stella 225
SaFiS wrote: Malossi shows the brackets mounted the other way around on their site… The instructions could have had at least one clear picture or diagram. ![]() |
1980 p200e, 1965 vbb, 2003 Stella
Posts: 6 Location: Midwest |
Sat, 09 Jul 2022 13:59:55 +0000
Malossi photo shows the metal brackets below the headset mounted in the opposite orientation.
Sat, 09 Jul 2022 15:14:20 +0000
I meant the metal brackets underneath. You have the plastic mounts like in the photo but the metal ones the other way around resulting in "squeezing" the screen…
![]() Sat, 09 Jul 2022 23:27:35 +0000
2007 Stella 225
SaFiS wrote: I meant the metal brackets underneath. You have the plastic mounts like in the photo but the metal ones the other way around resulting in "squeezing" the screen… Still trying to decide if I should be closer to headlight. I would need to reverse mirrors and try moving to riders side instead of wheel side. Would look closer to mirrors in Malossi picture. Pulled mounting bars upright a bit, technical term, to remove a bit of squeeze, looks better. Also replaced 30mm bolts with 35mm SS socket head cap screws. I couldn't fit lock washer on 30mm screw that came with it and used medium strength loc-tite. Now I have lock washer and loc-tite. ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
![]() Fri, 15 Jul 2022 23:41:52 +0000
2007 Stella 225
Put about 20 miles on, windscreen has air hitting about middle of full face helmet. Interesting putting hand up and feeling air stream and knowing that air isn't hitting you in chest any longer.
