1973 vbb 2008 250gt 1981 P200E
So I ran a search in the forum but I couldn't find the answer.
New battery installed in 81 p200e every two weeks dead and I drive 100 miles a week. I changed the regulator and still have the issue?
Thanks in advance
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
Thanks in advance
What have you actually measured or checked? What led you to replacing regulator?
So a voltage meter was put on when running and it showed it wasn't charging so the scooter mechanic suggested the regulator and it's an easy do it your self job and it was.
2007 Stella 225
2007 Stella 225
Honestly no, can you tell me where the fuse is in dummy terms like rear of engine by coil or?
Thanks!
@rowdyc avatar
@rowdyc avatar
Thanks!
Fuse is next to battery and connected to battery. Fuse would not be next to the coil because there's no coil and the ignition is not battery assitant. Blown fuse will not cause battery to go dead.
Since you're taking scoot to a mechanic for a dead battery, do you know how to use a mutimeter? Can you read a diagram? If you can't or don't want to learn take it back to mechanic but prob one that has a clue about these old machines.
We gonna need pics. Not that the problem is hard to figure out but seems like something is not connected right, wrong regulator or bad stator.
Your mechanic or you should have used the diagrams in the link above that match your scooter to make sure regulators is correct and wires are connected right.
Scooter running, need to check yellow wire for over 20 ac volts. Check grey wire for over 13 dc volts.
Upload pics of battery side with battery and connected regulator for better assistant of what really going on.
Will do thanks, I used the coil just a point of reference I realize it doesn't have a coil. The scoot was at the mechanic to install disc front brake and I asked him about the battery situation. I will check the fuse in the am again thanks
2007 Stella 225
2007 Stella 225
This is a search for Vespa p200 service station manual. You will find a few PDF manuals you can download. Service station manuals have troubleshooting in them and pictures with component locations.
https://www.google.com/search?q=vespa+p200+service+station+manual&oq=vespa+p200+service+station+manual&aqs=heirloom-srp..
[ Time: 0.0099s ][ Queries: 4 (0.0036s) ][ live ][ 343 ][ ThingOne ]
