2012 Vespa Gts 300 Super
Posts: 58 Location: Bridgeview, Illinois |
Hi, I currently have a 2012 GTS 300 and upgraded the shocks a few years ago but going over bad roads with bumps is still jarring and especially for the passenger. Have they made any improvements in ride quality with the 2022 GTS 300 HPE's? I know the small wheels don't help compared to a motorcycle. I like the Vespa but am seriously considering a motorcycle because of this issue.
![]() 2005 GT200L: (-Jiffy5-) 2013 GTV300ie, 2021 GTS 300hpe
Posts: 138 Location: Canada |
I am riding a 2013 GTV 300 with the stock suspension. Every once in a while I get a chance to ride my wife's 2021 GTS 300 hpe and it does have better suspension than mine. Enough so that I am considering getting some aftermarket shocks, but I am never riding 2up so I can't help you with an opinion there. Bigger wheels, better suspension, and a better passenger seat might still be what you are looking for.
Atypical Canadian
![]() 2009 Vespa S50(LX150 motor swap), 2006 Vespa GTS250ie
Posts: 2319 Location: Toronto, Canada |
![]() UTC
2019 GTS 300 HPE SuperTech 72,000km
Posts: 7220 Location: Batmania aka Melbourne, Aus |
![]() 2019 GTS 300 HPE SuperTech 72,000km
if it's jarring for the passenger with upgraded rear shocks then that sounds most likely that the preload is not correctly adjusted (or less likely they are worn out as adri was wondering).
Positive
I think I have about 5 or 6 thousand miles on the aftermarket shocks. It is possible I might have to try more preload. I think I'm at #2 out of 4 positions.
![]() UTC
Posts: 12502 Location: Fond du Lac, Wisconsin |
![]() 2015 GTS 2017 BV 350
The preload seems kind of low for two up. Good place to start.
If you can't make it work, and you like the GTS, I'd seriously consider the BV instead of a motorcycle....bit more power, bigger wheels, and better for a passenger.... |
![]() UTC
Posts: 2105 Location: Lancaster, U.K. |
![]() GTS 300ie Touring 2013 - Signora D'argento
spacedog wrote: I am riding a 2013 GTV 300 with the stock suspension. Every once in a while I get a chance to ride my wife's 2021 GTS 300 hpe and it does have better suspension than mine. |
![]() UTC
Onetechyguy wrote: I like the Vespa but am seriously considering a motorcycle because of this issue. |
![]() GTS300 Super (Mustard) GTS250 Super (Bulger)
Posts: 5071 Location: Tempe, AZ |
The HPE Vespas have slightly thicker grips and an improved seat, at least for the rider. I cannot vouch for the pillion seat.
![]() 2006 Vespa GT (Rocket): 2007 Vespa GT (Vanessa): 2009 Yamaha Zuma 125: 2018 Yamaha Xmax (Big Ugly), 2023 Vespa GTS300 (Ghost)
Posts: 5339 Location: Jacksonville, Florida |
Onetechyguy wrote: Hi, I currently have a 2012 GTS 300 and upgraded the shocks a few years ago but going over bad roads with bumps is still jarring and especially for the passenger. Have they made any improvements in ride quality with the 2022 GTS 300 HPE's? I know the small wheels don't help compared to a motorcycle. I like the Vespa but am seriously considering a motorcycle because of this issue. The best shocks in the world will never correct for this design. Certainly it can be improved, and postings are saying that the new HPE is better, but if you want it a lot better, it is best to find something with lower unsprung weight with longer suspension travel. Bill
Positive
![]() UTC
Red Devil SH150i (11,000)
Posts: 3312 Location: Orange Park Florida |
![]() Red Devil SH150i (11,000)
You could move to Florida. Our roads are the best of the 6 states I've lived in. The biggest bumps here are the thick painted lines and arrows. Better hurry because we'll be under water in about 10 years
![]() UTC
something else that is often forgotten when discussing ride comfort:
tires. in particular pressures. both for single rider and especially for with a passenger. also different tire models & brands will be different as the different construction will flex differently. compare these before judging. |
Onetechyguy wrote: I think I have about 5 or 6 thousand miles on the aftermarket shocks. It is possible I might have to try more preload. I think I'm at #2 out of 4 positions.
Positive
![]() UTC
Sledge wrote: My Kama Scootra book says to try all positions until you find the one that's best for you. PS, nice to see it's in Urban Dictionary https://www.urbandictionary.com/define.php?term=Kama%20Scootra |
![]() LX190 Friday afternoon special, [s]Primavera[/s], S50, too many pushbikes
Posts: 10941 Location: Hermit Kingdom |
steelbytes wrote: Is that available as a PDF download? Or is it on Audible? PS, nice to see it's in Urban Dictionary https://www.urbandictionary.com/define.php?term=Kama%20Scootra ![]()
Positive
![]() UTC
![]() UTC
![]() UTC
Touring300 wrote: The Sprint position. |
![]() UTC
![]() UTC
