You'd think I have better things to do!
For fun, I thought I'd remove the DB killer from the Akrapovic muffler on my Sprint 150.
It's no small task to remove it. I will get a slide hammer to get it out because that's how Robot does it. I got the screw out using an 8mm socket. I was afraid to use the 4mm allen key.
Then I read some MV history, and most (not all) say its way to loud.
So then I find a you Tube video where the guy uses an aftermarket DB killer and it sounds like this product from Pipe Werx hits the middle ground of noise level.
Has anyone tried after market DB killers on their Akrapovic mufflers?
