Would appreciate some help —
I'm trying to unscrew the gear oil drain bolt on my 2022 GTS for the first time and, for some reason, I'm having a really tough time with it. I checked the service manual to make sure I am in fact working on the right bolt and I confirmed that I am using the right hex bit (6mm). I've tried using a 6" extension on both a 1/4" and 3/8" ratchet to reach the bolt, but the length of the tool makes it kind of wobbly and that makes it kind of difficult to get a solid grasp on the bolt. Every time I try to unscrew the bolt, I feel like the hex bit is going to give way before I actually get the bolt to turn. Looking at videos of other folks doing it, though, it doesn't seem like they struggle very much and I know the bolt is supposed to only be torqued to 12 foot pounds.
What am I doing wrong? I feel silly not being able to undo this one bolt as this is supposed to be a quick service task, although Piaggio sure didn't put it in an easy to access spot.
