I bought Buchsenfuchs bushings from SIP
https://www.sip-scootershop.com/en/product/rubber-engine-mounting-bush-kit-shock-absorber-rear-12x38x20-mm-left-right-top-buchsenfuchs_30568110
Sadly the rear don't fit my SIP shocks as the inner diameter of the bushings is too small. OEM shocks have a 13mm shaft, the SIP shocks have 15mm. the Buchsenfuchs bushings are 12mm diameter and are too firm to stretch to 15. OEM bushings are 14mm (these are my stretched ones that i have been using on my sip shocks)
Haven't yet tried the front ones that I also bought ...
