Fri Aug 05, 2022 11:04 am
Fri Aug 05, 2022 11:04 am linkquote
Are you guys doing the coolant flush every two years as recommended? What is the best coolant to use if you're going to flush the system? Should I stick with the original stuff that comes in the scooters new or something else?
Fri Aug 05, 2022 11:20 am
Buddy 900
Buddy 900
Fri Aug 05, 2022 11:20 am linkquote
Using Maxima coolant from Amazon for my motorcycle, scooter west also lists it for scooters
https://www.scooterwest.com/maxima-coolanol-ready-to-use-coolant-1-2-gallon-64-oz.html
Also been using Quicksilver synthetic oil and Quicksilver dot 4 brake fluid, more economical than Motul and some of the other big brands and it's made by Mercruiser, the Mercury boat engine gurus.
Fri Aug 05, 2022 11:57 am
Fri Aug 05, 2022 11:57 am linkquote
Mercury makes brake fluid??
Fri Aug 05, 2022 12:12 pm
2018 Vespa 300 GTS Touring
Fri Aug 05, 2022 12:12 pm linkquote
If you doing the coolant flush then why not do it yearly. Cost of materials is low, your time and effort is costed out to zero.
I change engine oil twice a year once in Spring and then late in the fall. I do a coolant flush every year early in the spring along with a change of the spark plug.
Routine maintenance like air filter cleaning/coolant flush/ spark plug/ oil change etc if one is doing it themselves then the cost of the materials is relatively low and you get to keep your Vespa in tiptop shape or hope to do so.
Fri Aug 05, 2022 12:28 pm
Buddy 900
Buddy 900
Fri Aug 05, 2022 12:28 pm linkquote
yes, that's why their boats can stop on a dime.
They also make gear oil
Fri Aug 05, 2022 1:15 pm
2019 GTS300
2019 GTS300
Fri Aug 05, 2022 1:15 pm linkquote
I change every two years. Coolanol works for me. Generating excess hazmat waste to change it more frequently just doesn't make sense (for me, YMMV).
Fri Aug 05, 2022 1:17 pm
Fri Aug 05, 2022 1:17 pm linkquote
No, they package and sell it at a vast mark-up! Used in their engine tilt and trim hydraulics. Ordinary DOT4 works just as well at 1/4 the price.
Fri Aug 05, 2022 1:47 pm
Buddy 900
Buddy 900
Fri Aug 05, 2022 1:47 pm linkquote
$7.19 USD for 12oz seems ok,
what are you paying?
Fri Aug 05, 2022 2:56 pm
Fri Aug 05, 2022 2:56 pm linkquote
I'm remembering UK Mercury prices from when I was back in the UK. Anything smelling of 'marine' there goes for twice the price - add a well-known name and it goes up even more.
Fri Aug 05, 2022 10:50 pm
GTS 300ie Touring 2013 - Signora D'argento & GTS 300ie HPE 2022 - Regina Arancione.
Fri Aug 05, 2022 10:50 pm linkquote
That's a great maintenance routine you have baba. I do my own wrenching and try to keep up with recommended schedules. I find that regular maintenance not only is good for your scooter, but therapeutic to know it's being looked after properly and to be able to check the general condition of your scooter whilst you're doing it.
Sat Aug 06, 2022 3:29 am
Sat Aug 06, 2022 3:29 am linkquote
Ah, that makes a bit of sense, though not too well-versed on boat engines other than outboards. Maybe I should, living about 2 miles away from Mercury headquarters. It's like living in Pontaderra or something! Anyway, never saw a Brake Fluid Division building here, lol.
BTW, I think my last bottle of brake fluid was around $4 IIRC.
Sat Aug 06, 2022 8:59 am
Sat Aug 06, 2022 8:59 am linkquote
I'm on a two year schedule for my GTS & BV. I'm not going to even attempt to do the brakes on my 2020 BV again. The rear is a bitch!
Sat Aug 06, 2022 1:27 pm
2006 GTS 250
2006 GTS 250
Sat Aug 06, 2022 1:27 pm linkquote
I change my scooter coolant only when it's needed. I have this drop squeeze thingy that tells me what it's time to change.
Sat Aug 06, 2022 10:39 pm
Sat Aug 06, 2022 10:39 pm linkquote
I use a calendar
  DoubleGood Vespa Design
[ Time: 0.0279s ][ Queries: 5 (0.0068s) ][ Debug on ][ 211 ][ Thing One ]
