Has anyone used a Lithiem battery on a 50cc, I'm tired of buying lead acid batteries. My ET isn't ridden much, sits for long periods in storage. Even on batt tender they readily fail. Thanks for any info.
Cheers
Wed, 10 Aug 2022 22:11:44 +0000
Cheers |
Vespa Sprint Sport S 125cc
Posts: 295 Location: England |
Mon, 22 Aug 2022 15:59:05 +0000
I did look at this for an Elettrica (which still has a 12v battery to run the instruments and to power up the bike).
A few things I came across: Lead acid loses about 4% a week, and if it drops below 50% - they start degrading. So a 6ah battery only had 3ah that are usable. Lithium barely uses anything while resting. You can use almost 100% of a lithium battery, so be careful because most of the lithium batteries available say "6ah equivalent", when they're actually a much much smaller capacity! Most companies try to hide the real size of each lithium battery. The other thing is that lithium can have problems if it's overcharged. When people charge lead acid and lithium batteries, they usually buy different chargers. The main sticking point for me was that the bike charging system will not know that it's a lithium battery - so will the lifespan be less if it's always being charged wrong? |
![]() 1979 P200E (sold) / ZNEN Amore 150 (sold) / Genuine Buddy 170i / Genuine Stella 4T /Aprilia Sportcity One 50
Posts: 1779 Location: Grand Rapids, MI |
Mon, 22 Aug 2022 16:13:28 +0000
I have one in my Aprilia Sportcity 50cc. Definitely get a Li battery charger for proper charging.
I've had no worries. The only caveat - which was pointed out to me - is sub zero temps. |
Mon, 05 Sep 2022 20:16:06 +0000
Thanks for the input. Still on the
![]() Did read a post on application to the ET50 - was hoping poster would chime in. Me too, how does the charging system tell if it's a Lithium or lead acid? |
Mon, 05 Sep 2022 23:59:44 +0000
Highly recommending trying AGM (absorbed glass mat) batteries. Much better than lead acid but not as amazing as lithium ion. For my motorcycle and vespas, I've purchased a brand called MotoBatt. I'm not an expert on Lithium Ion batteries but I believe normal charging systems may overcharge one of those. I bought this model for my 2004 and 2005 ET50s, MBTX4U. Hope this helps.
Tue, 06 Sep 2022 13:20:57 +0000
DCet2 wrote: Highly recommending trying AGM (absorbed glass mat) batteries. Much better than lead acid but not as amazing as lithium ion. For my motorcycle and vespas, I've purchased a brand called MotoBatt. I'm not an expert on Lithium Ion batteries but I believe normal charging systems may overcharge one of those. I bought this model for my 2004 and 2005 ET50s, MBTX4U. Hope this helps. From what I've heard the Li batteries don't like the pulse charging that standard battery chargers use. But I've read a lot of differing opinions. I did buy a Li specific charger. |
![]() Tue, 06 Sep 2022 15:27:33 +0000
Vespa C38 - S50 4T Super.
Posts: 100 Location: Netherlands |
![]() Vespa C38 - S50 4T Super.
From what I can gather, many Lithium batteries have built in BMS (Battery Management System circuit). They can use anything from 12-16 volts and safely put correct amount of energy into the cells. No need for specific wall charger. The charging system in your bike is not Lithium specific. That same BMS controls the output and prevents the batteries from being discharged too much.
Different brands will have different BMS, or none at all, so you can expect different results from different brands of Lithium batteries.
Positive
Thu, 08 Sep 2022 02:45:15 +0000
Kudos for input all. Decided to go with the MBTX4U, will
give it a try. Again, thanks all. Happy rides! ![]() |
![]() 2008 MP3 500, 2013 BV350, 2020 Vespa Sei Giorni, 2008 Vespa S150
Posts: 8891 Location: Ashburn, Va. Home to the Internet |
Thu, 08 Sep 2022 22:32:45 +0000
My answer to your question would be, why? What is the lead acid not doing for a third of the cost of lithium?
![]() 2009 Vespa S50(LX150 motor swap), 2006 Vespa GTS250ie
Posts: 1739 Location: Toronto, Canada |
Thu, 08 Sep 2022 23:21:03 +0000
WEB-Tech wrote: My answer to your question would be, why? What is the lead acid not doing for a third of the cost of lithium? Secondly, it's not saving several pounds, which is a nice bonus on a 50cc. |
Fri, 09 Sep 2022 14:43:49 +0000
WEB-Tech wrote: My answer to your question would be, why? What is the lead acid not doing for a third of the cost of lithium? |
Fri, 09 Sep 2022 15:05:42 +0000
Good point too. They typically have more voltage and cold cranking amps.
![]() Vespa GTS 250 , Baotian 70cc rat scooter, Yamaha V50M 1979
Posts: 522 Location: Wales |
Fri, 09 Sep 2022 15:14:17 +0000
My Vespa ET4 125 I just bought back from someone who moved to Bulgaria has a random flat lithium battery in it which I charged and now starts scooter. We will see how it performs on the road. Don't think it's meant for a 125 but we will see.
![]() LXV 150 3v ie. Midnight Blue (Sold) Now Honda Zoomer X
Posts: 3980 Location: Kingdom of Lanna |
Mon, 12 Sep 2022 12:15:31 +0000
semoir wrote: Me too, how does the charging system tell if it's a Lithium or lead acid? ![]() But I use it to charge batteries on motorbikes. |
Wed, 14 Sep 2022 14:47:59 +0000
semoir wrote: Not a hard decision after all. Tks all, ride safe 👍! Also, be careful about being trapped in a cave-in and suffocating to death, because your odds of that happening - statistically - are 1 in 152,822. Honestly, I think that's a much more serious concern. |
Fri, 16 Sep 2022 16:49:41 +0000
semoir wrote: Not a hard decision after all. Tks all, ride safe 👍! 🙈 |
Tue, 20 Sep 2022 23:31:58 +0000
seamus26 wrote: Be careful out there, friends. According to CNET your odds of suffering a Li battery fire are about 1 in 10,000,000. That's staggering. Also, be careful about being trapped in a cave-in and suffocating to death, because your odds of that happening - statistically - are 1 in 152,822. Honestly, I think that's a much more serious concern. MotoBat brand is a first, we'll see. Cheers! |
21 Racing 60s 95 Turbo RK
Posts: 54 Location: UMD |
Thu, 22 Sep 2022 14:43:34 +0000
Thu, 22 Sep 2022 14:53:57 +0000
WEB-Tech wrote: My answer to your question would be, why? What is the lead acid not doing for a third of the cost of lithium? 1) Doesn't self discharge when not in use - lead discharges at about 4% per week. 2) Happy with long term storage. Lead starts to degrade at under 50% charge - so should be trickle charged over Winter or it doesn't tend to last. Yesterday, I found an old iPad that I hadn't used in 5 years. Plugged it in and it turned on straight away. By contrast, I left a car sat for a single winter and the lead battery was scrap after the 3-4 months. Lead is dirt cheap and is great for a daily driven / ridden vehicle - but most Vespas aren't run all year round. |
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 42811 Location: Pleasant Hill, CA |
Thu, 22 Sep 2022 17:17:06 +0000
The temperature range is not good - they can't be charged below 5C without sustaining some damage, and below 0C is a complete no-no. Some have built-in heaters - but you have to ensure they get continuously maintained during cold spells when not in use.
Thu, 22 Sep 2022 17:34:53 +0000
Louiesdad wrote: Last 10-11 years So far an old, neglected, and abused (by the previous owner) Antigravity battery is still kicking just fine though, so even though they did not sponsor me, if I had to recommend one brand over the others, that's where I would put my money. |
Sat, 24 Sep 2022 15:10:19 +0000
Knockoffs of anything seem to fail real fast, just stick with brand names products.
![]() LX190 Friday afternoon special, Primavera, some pushbikes
Posts: 9482 Location: Hermit Kingdom |
Sat, 24 Sep 2022 22:39:38 +0000
Louiesdad wrote: Knockoffs of anything seem to fail real fast, just stick with brand names products. |
Sat, 24 Sep 2022 22:53:08 +0000
znomit wrote: Such as? |
