Sun, 14 Aug 2022 03:07:10 +0000
I have a Piaggio MP3 250 (2008 model) that has a wire going to the front brake caliper. All the literature & manuals I have read DO NOT mention linked brakes or ABS for a 2008 model. Can anyone tell me what the wire is for please?
![]() Sun, 14 Aug 2022 04:18:05 +0000
2019 GTS300 Supertech E3 50,000km
Posts: 4042 Location: Batmania aka Melbourne, Australia |
![]() 2019 GTS300 Supertech E3 50,000km
the manual says that's for the tone wheel (nothing to do with the calliper).
ie speedo https://manuals.wotmeworry.org.uk/Piaggio/Piaggio%20MP3/MP3%20250/MP3%20250%20Workshop%20Manual.pdf |
Thu, 18 Aug 2022 00:39:09 +0000
Hi...thanks for the reply. I can't find any reference to it in the manual, the wiring diagram in the manual isn't legible in the pdf download. The mp3 has the connector on the other front brake caliper as well. 2 speedo (tone wheel) connections would not be required surely?
![]() Thu, 18 Aug 2022 00:43:43 +0000
Fred500 wrote: Hi...thanks for the reply. I can't find any reference to it in the manual, the wiring diagram in the manual isn't legible in the pdf download. The mp3 has the connector on the other front brake caliper as well. 2 speedo (tone wheel) connections would not be required surely? check the wiring diagrams at https://manuals.wotmeworry.org.uk/Piaggio/Piaggio%20MP3/MP3%20250/ |
Sun, 21 Aug 2022 10:06:58 +0000
Yep, you are correct .....though why a vehicle needs sensors on both wheels I can't imagine.
Tomorrow I'll try to solve my new problem ....the horn sounding when I use the tilt lock to lock the wheels in the vertical position. The 1st time this happened it was cured by topping up the tilt lock reservoir. Today I experimented with locking the system with the MP3 leaning over (wondered if when 'righting' the machine & putting it on the center stand, a wheel could be changed)....however it was difficult to get the system unlocked + now the horn sounds whenever the tilt lock is used (locked). I reminisce over the 1960's, when to change a back wheel on my Lambretta took less than 5 minutes, or to take the crankshaft out took a bit more than an hour with only 1 special tool. |
2015 MP3 500 ie Business
Posts: 1061 Location: Belgium |
Sun, 21 Aug 2022 10:51:38 +0000
And would you really want to relive the 60s? No internet, no forums, no smartphones, cars that only wanted to start when they were "in the mood", the misery of carburetors, vapor lock conditions, ignition systems with points and condensers, bias ply tires, drum brakes, stopping distances that ranged anywhere from "eventually" to "infinity" etc, etc, etc.
Thanks, but no thanks. |
Tue, 23 Aug 2022 06:01:03 +0000
MP3 500 HPE 2019
Posts: 75 |
Fred500 wrote: Yep, you are correct .....though why a vehicle needs sensors on both wheels I can't imagine. Tomorrow I'll try to solve my new problem ....the horn sounding when I use the tilt lock to lock the wheels in the vertical position. The 1st time this happened it was cured by topping up the tilt lock reservoir. Today I experimented with locking the system with the MP3 leaning over (wondered if when 'righting' the machine & putting it on the center stand, a wheel could be changed)....however it was difficult to get the system unlocked + now the horn sounds whenever the tilt lock is used (locked). I reminisce over the 1960's, when to change a back wheel on my Lambretta took less than 5 minutes, or to take the crankshaft out took a bit more than an hour with only 1 special tool. |
Tue, 23 Aug 2022 06:23:51 +0000
Posts: 7 |
It's the same with cars and vans jumped in my van this morning front tyre flat no spare no jack just the liquid now tried that no luck it's going backwards
Tue, 23 Aug 2022 07:58:03 +0000
Fred500 wrote: Oh dear me....a tantrum And yes, I'll be the first to admit that progress isn't always progress such as the removal of the full size spare as pointed out (a nickel and dime cost cutting measure by manufacturers) or the oversaturation of tech especially the Euro techno garbage (looks great, breaks once out of warranty) found in European vehicles. |
