Thu, 18 Aug 2022 01:40:11 +0000
MP3
MP3
Thu, 18 Aug 2022 01:40:11 +0000 quote
Just back in LA and my MP3 400 needs the idle hole cleaned and a spark plug. Runs well , just won't idle.
As I have been away so long , needing desperately a MP3 mechanic to do a quick fix solution
In Los Angeles and needing help. Love my MP3 , wont me that much to make it happy again
Please
Thu, 18 Aug 2022 12:57:16 +0000
2015 MP3 500 ie Business
Thu, 18 Aug 2022 12:57:16 +0000 quote
How long has the bike been sitting? If it sat for more than 90 days then I hope you used a fuel stabilizer before leaving.
Modern day fuels go bad very quickly.
Thu, 18 Aug 2022 18:02:50 +0000
MP3 500 HPE 2019
MP3 500 HPE 2019
Thu, 18 Aug 2022 18:02:50 +0000 quote
as above some clean petrol added and give it a good strong ride around, avoiding the CHP
Thu, 18 Aug 2022 21:38:23 +0000
MP3
MP3
Thu, 18 Aug 2022 21:38:23 +0000 quote
All great points and very true. However need a LA mechanic that loves Piaggio Vespa MP3.
Must me someone who is a great scooter spanner man.
Thu, 18 Aug 2022 22:47:42 +0000
Thu, 18 Aug 2022 22:47:42 +0000 quote
Not in my experience. My MP3 starts right up after winter storage, no stabilizer added for a few years now.
Fri, 19 Aug 2022 01:26:21 +0000
Fri, 19 Aug 2022 01:26:21 +0000 quote
When it comes to fuel
Full tank is better than an partially full one,
Dry is better than wet
Shade is better than the sun
Fri, 19 Aug 2022 13:03:19 +0000
Fri, 19 Aug 2022 13:03:19 +0000 quote
The ethanol in the fuel is the deadly killer here, such as fuel pumps, injectors, etc.
⬆️    About 28w elapsed between posts    ⬇️
Fri, 03 Mar 2023 00:00:02 +0000
Piaggio MP3 500
Piaggio MP3 500
Fri, 03 Mar 2023 00:00:02 +0000 quote
If your MP3 hasn't been heavily modified like mine, I would suggest going to Vespa of Sherman Oaks to get it properly serviced.
Mine being heavily modified, I take it to Pena Racing (1601 S. Alameda Street). They are a father and son team that is honest and awesome to work with. Ask for Edwin and tell him Alen with the Piaggio MP3 500 sent you.
Fri, 03 Mar 2023 00:05:50 +0000
MP3
MP3
Fri, 03 Mar 2023 00:05:50 +0000 quote
Do you have a contact number , want to reach out before I arrive.
Also anyone good for tyres as most tyre places hate MP3 sadly
Fri, 03 Mar 2023 04:00:18 +0000
Piaggio MP3 500
Piaggio MP3 500
Fri, 03 Mar 2023 04:00:18 +0000 quote
(323) 273-9073, Ask for Edwin, he's the owner. Tell him Alen with the Black Piaggio MP3 500 referred you from a forum. He's replaced my tires before.
Recently he worked on my MP3 500 which stopped running and sat there for 5 years. I tried going to 2 other mechanics and they weren't able to fix it, but at Pena we finally got it up and running again.
Side Note:
If you ever have battery drain problems where the bike won't start up even after you tried everything else (putting in new battery etc) make sure you check the hidden 30amp fuse in the starter relay which is near the front (close to the battery) in the compartment under the seat. Our Piaggio is wired and built very differently from most bikes, making it hard for most mechanics to diagnose this properly.
Fri, 03 Mar 2023 04:04:28 +0000
MP3
MP3
Fri, 03 Mar 2023 04:04:28 +0000 quote
I will be in LA 1st May , we should have a ride, I am usually in Beverly Hills and free most days
Any other MP3 in LA May 2023 , let's plan a run
  DoubleGood Design
[ Time: 0.0270s ][ Queries: 4 (0.0069s) ][ Debug on ][ 277 ][ Thing Two ]
