Sun, 21 Aug 2022 02:11:57 +0000
My first post here, I recently purchase a 2021 GTS 300 HPE. I find that the headlight casts a large pattern of shadows. Has anyone found a replacement headlight assembly which has a better light pattern?
Positive
![]() 2015 GTS 300 Super (Melody: 2015-2021, RIP), 2022 GTS SuperTech (Thelonica; bit the dust 02-22-23)
Posts: 3909 Location: Asbury Park, NJ |
Sun, 21 Aug 2022 03:26:25 +0000
Firstly, Hi, and welcome.
So far, I know of no direct replacement/upgrade for the current HPE lineup, only the previous (<2020, US) models. In my experience, the existing headlight setup works fine, in fact, a good deal better than the halogen step on my 2015 GTS; I don't find an issue with the beam pattern. |
![]() GTS 300 Super
Posts: 669 Location: Los Angeles, CA |
Tue, 23 Aug 2022 22:38:17 +0000
Same issue here with 2021 GTS, casts a lot of shadows and light beam is very narrow. I tried adjusting it from behind the lamp, but not much improvement.
Positive
![]() 2020 GTS 300 hpe Touring
Posts: 433 Location: Upstate SC |
Sat, 27 Aug 2022 20:57:49 +0000
If you really think that the GTS 300 hpe LED headlight is inadequate, you could always add an auxiliary light. For example from Clearwater Lights:
https://www.clearwaterlights.com/products/darla-vespa-piaggio I ride my Vespa a lòt at night time and while I think an auxiliary light might be worthwhile, I really haven't felt this is necessary. I do have LED switchback turn signals though, like the ones that Robot shows in the video below. Because I care about being seen and for that having more than one light both in the front and rear works really well. Last edited by giallo on Sat, 27 Aug 2022 22:23:06 +0000; edited 1 time |
Sat, 27 Aug 2022 21:57:50 +0000
Gts hpe supertech
Posts: 88 Location: Minneapolis |
Gts hpe supertech
The only replacement I am aware
Of is this one https://www.scooterwest.com/black-out-led-headlight-assembly-with-halo-light-bar-gts-super-300-hpe-2020-later.html Not sure if it's much different from the stock one though (besides the daytime running light bar across the middle). |
Sat, 27 Aug 2022 23:17:09 +0000
Snoopzilla wrote: Not sure if it's much different from the stock one though (besides the daytime running light bar across the middle). |
Vespa GTS hpe 2022
Posts: 4 Location: Derbyshire |
Tue, 30 Aug 2022 17:09:59 +0000
Maxx28
How did you adjust the light beam? I have a 2022 GTE hpe with LED light. I get flashed by oncoming traffic so guessing it's set too high. For the life of me I cannot figure it out. There doesn't seem to be an adjustment screw! |
Tue, 30 Aug 2022 20:38:00 +0000
Gts hpe supertech
Gts hpe supertech
Pdm23 wrote: Maxx28 How did you adjust the light beam? I have a 2022 GTE hpe with LED light. I get flashed by oncoming traffic so guessing it's set too high. For the life of me I cannot figure it out. There doesn't seem to be an adjustment screw! https://www.manualslib.com/manual/1631378/Piaggio-Vespa-Gts-300-Hpe-2019.html?page=72
Positive
![]() GTS 300 Super
Wed, 31 Aug 2022 19:12:03 +0000
Pdm23 wrote: Maxx28 How did you adjust the light beam? I have a 2022 GTE hpe with LED light. I get flashed by oncoming traffic so guessing it's set too high. For the life of me I cannot figure it out. There doesn't seem to be an adjustment screw! My 2010 GTS halogen is 10 times better for night riding. |
Wed, 31 Aug 2022 19:52:56 +0000
Regarding the GTS 300 headlight adjustment, this is the instruction graphic from the manual.
Position yourself on an even surface about 10 meters (10.93 yards) from a wall and your light should be visible slightly below the horizontal line. Best to check first before you adjust anything. ![]() Last edited by giallo on Wed, 31 Aug 2022 21:26:33 +0000; edited 1 time |
![]() 2021 Vespa GTS 300hpe 75th anniversary
Posts: 58 Location: St Paul, Minnesota,USA |
Wed, 31 Aug 2022 20:27:20 +0000
I will say the first time I turned on the headlight on my 2021 GTS first thing I saw was shadows all over the place. Hit me without even thinking about it.
Thu, 01 Sep 2022 17:25:59 +0000
Afflicted wrote: I will say the first time I turned on the headlight on my 2021 GTS first thing I saw was shadows all over the place. What I see are bright and less bright areas close by. There's no need to look ten or even 30 feet ahead of you, since when you ride at 25 mph (40 kmh) it's about 37 feet (11m) per second. That means one has to look much farther ahead when traveling even at such a relatively low speed. The Illumination further out is adequate, as it should be. Thinking back, I used to ride motorcycles at 100 mph with headlights that had a fraction of the power of today's LEDs, the Vespas included.
Positive
![]() Sun, 04 Sep 2022 21:50:52 +0000
2021 Vespa GTS 300 Super HPE
Posts: 109 Location: Fort Pierce, Florida |
![]() 2021 Vespa GTS 300 Super HPE
The headlight on my 2021 HPE casts shadows as well, it's just horrible to ride at night
Positive
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 42775 Location: Pleasant Hill, CA |
Sun, 04 Sep 2022 22:17:16 +0000
Why do you guys say these are casting shadows? Objects that get in the way of the light cast shadows. If the light isn't uniform in the first place, it's just poor lens and reflector design. Complain about that, sure. But shadows?
Sun, 04 Sep 2022 22:36:45 +0000
jimc wrote: Why do you guys say these are casting shadows? Objects that get in the way of the light cast shadows. If the light isn't uniform in the first place, it's just poor lens and reflector design. Complain about that, sure. But shadows?
Positive
![]() Sun, 04 Sep 2022 23:02:14 +0000
2019 GTS300 Supertech E3 50,000km
Posts: 4030 Location: Batmania aka Melbourne, Australia |
![]() 2019 GTS300 Supertech E3 50,000km
jimc wrote: Why do you guys say these are casting shadows? giallo wrote: if you look at anything that close by, chances are you going to end up in a rather unfortunate situation. |
Fri, 09 Sep 2022 08:45:37 +0000
I don't get how they thought this headlight beam pattern was good enough. Thankfully I don't ride at night as much as I used to because it's definitely less confidence inspiring then the halogen headlight I had in my 2015 GTS.
Sat, 07 Jan 2023 03:23:15 +0000
Primavera150
Posts: 1 Location: Tennessee |
Primavera150
New to the forum and a first time scooter rider. I just started riding my 2021 Vespa Primavera 150 at night and found the headlamp pattern on the road to consist of alternating bands of light and dark that I find provides such poor coverage I will avoid riding at night. I am so surprised how Piaggio would design such a poor headlamp reflector design on what is otherwise a fabulous machine. I read some of the post on this topic from a few months ago and didn't see any solutions...anybody got one?Thanks
![]() Wed, 01 Feb 2023 22:04:18 +0000
Was looking at building my own headlight with aftermarket parts, just not sure what the max watts the wiring could handle for the stock 2021 GTS 300 HPE
![]() Wed, 01 Feb 2023 22:25:03 +0000
Pegasus Prime wrote: Was looking at building my own headlight with aftermarket parts, just not sure what the max watts the wiring could handle for the stock 2021 GTS 300 HPE |
![]() Wed, 01 Feb 2023 22:31:49 +0000
Vespa GTS300 SuperTech (iScoot); Vespa GTS250ie
Posts: 47 Location: New Orleans, LA |
![]() Vespa GTS300 SuperTech (iScoot); Vespa GTS250ie
The first mod to my '21 HPE was Aux lights hung from a new front rack bought for the purpose.
I rode for an hour or two on unlit roads last weekend, and I was not worried about the "shadows". I was worried about deer and other critters. I worried that I'm not shining into the eyes of oncoming drivers since the bulbs are all rather bright. |
![]() Fri, 31 Mar 2023 01:21:53 +0000
so ... anyone have solved this?
does adjusting the light make this good enough to not be annoying? or have ya'll all given up and added extra lights or different headlight? although I generally don't ride at night this has recently frustrated me a few times (most recently dodging roos) |
![]() Vespa Primavera 50 (sold), 2021 Vespa Sprint 150 (sold), 2022 Sei Giorni 300ie
Posts: 796 Location: Naples Florida USA |
Mon, 03 Apr 2023 09:59:17 +0000
bobbyoakes wrote: The first mod to my '21 HPE was Aux lights hung from a new front rack bought for the purpose. I rode for an hour or two on unlit roads last weekend, and I was not worried about the "shadows". I was worried about deer and other critters. I worried that I'm not shining into the eyes of oncoming drivers since the bulbs are all rather bright. |
![]() Sun, 09 Apr 2023 22:13:15 +0000
mankite wrote: Does anyone know if this issue was addressed in the 2023 GTS? |
![]() 2022 gts 300 touring
Posts: 91 Location: pennsylvania |
Sun, 09 Apr 2023 22:44:43 +0000
my light are pretty good no complaint ,they better than my 2003 Ford ranger
![]() '20 GTS300 Touring, '10 GTS300 Super (sold)
Posts: 137 Location: Ruidoso Downs, New Mexico |
Mon, 10 Apr 2023 23:11:22 +0000
tinddu wrote: my light are pretty good no complaint ,they better than my 2003 Ford ranger ![]() |
Mon, 10 Apr 2023 23:13:47 +0000
SteelBytes wrote: The light is different in the 2023. Can see in the pictures that the horizontal 'shelf' that goes straight across the middle now has a dip in the middle. But no idea if it's actually better |
![]() Mon, 10 Apr 2023 23:35:51 +0000
McRuss wrote: If you are talking about the photo Pegasus Prime posted, he says that is a 2021. If there is a different photo, I don't see it. |
Thu, 13 Apr 2023 16:07:16 +0000
I've had the opportunity to ride at night the last few days and observed my headlight beam more closely. I've noticed that there is no longer a 'high beam' and 'low beam' with the LED headlight on my 2020 GTS300. The beam remains at the same level, it is the brightness that changes. And it is a wide beam but narrow vertically. Sorta like this:
_________________ [_________________] But it is pretty bright, I would just like to have it a little higher (must find adjustment screw) to project further down the road (where we are supposed to be looking ) |
![]() Thu, 13 Apr 2023 22:53:22 +0000
McRuss wrote: I would just like to have it a little higher (must find adjustment screw) to project further down the road (where we are supposed to be looking ) https://modernvespa.com/forum/post2578571#2578571 |
![]() Fri, 12 May 2023 10:04:07 +0000
There are two new style headlights for the HPE at SIP, a little pricey at $350 for one, but debating on ordering
Headlight Unit ZELIONI Black Edition LED https://www.sip-scootershop.com/en/product/headlight-unit-zelioni-black-edition-led_ZELHLGTHPB?q=ZELIONI or https://www.sip-scootershop.com/en/product/headlight-unit-zelioni-black-edition-led_ZELHLGTHPC?q=ZELIONI ![]() ![]() |
![]() Thu, 01 Jun 2023 15:11:19 +0000
ET3 & PX150 & GTS 300 Super Sport
Posts: 1815 Location: Berlin |
![]() ET3 & PX150 & GTS 300 Super Sport
![]() Tue, 06 Jun 2023 15:08:43 +0000
Billrush wrote: Can we have a photo of your aux light set up? ![]() on the DGR recently. ![]() The straps on the luggage rack were to solve a different problem... a place to secure a fuel bladder. |
![]() Wed, 07 Jun 2023 05:32:58 +0000
bobbyoakes wrote: Sorry for the delayed response. These lights are from Amazon, less than $30 for the pair. I did an IBA ride recently which means that I drove overnight with no visibility issues. |
![]() Wed, 07 Jun 2023 19:37:21 +0000
SteelBytes wrote: Do you find it feels weird when turning a corner that the main headlight moves but the extras you added don't? |
![]() Wed, 07 Jun 2023 23:13:42 +0000
bobbyoakes wrote: No, not at all. do you have a link to the same unit on amazon and/or some close up photos of the lights? |
![]() Wed, 06 Sep 2023 18:42:29 +0000
Finally got the updated HPE Headlight in the mail today, took a long while for SIP to have them in stock and about a week to ship from Germany to South Florida, will post an update in a few days to compare pre / post install light action
![]() New Headlight ![]() New Headlight Side ![]() New Headlight Box |
