Greetings from Colorado!
1st post and I'm sure many more to come.
I misplaced the OEM washers when removing my mirrors. Anyone out there know what part numbers they are and where to buy?
Thank you!
2019 GTS 300 HPE SuperTech 71,000km
from the Elettrica parts list. expect would match the Primavera
https://www.af1racing.com/ProdImages/st3/EVE5000US4.pdf
You could go down to your local hardware store with one of the mirrors and get a washer and lock washer for both sides
@jimjar avatar
2012 LX150ie
@jimjar avatar
2012 LX150ie
Tierney, that's what i would do.
Thanks for replies! I'll head to my local hardware store. 👍
@californiacruising avatar
2015 Sprint 150, 2018 GTS 300
If you have an Ace Hardware in your area they have an excellent nut, bolt and fasteners section
I'm pretty sure it's an 8mm washer, the kind you can buy in a pack of five for $1 or in Piaggio packaging for $9 each.
I do. Thank you!
Thanks. I appreciate the info. I just took a measurement and it is indeed 8mm.
I was sorting my boxes of Vespa bits and pieces and found the original mirrors that came with my supertech, with them were two unopened little bags of two washers each - one silver plain and one black domed. Why did i have these? Because i didn't like the mirrors on my supertech when i bought it as they were shorter than my old gts but i did like the newer style. So i had bought some mirrors that were for a 2015(?) Primavera that have the new style but old length and also have reverse thread on the left. Perfect, i was happy. The new mirrors had come with washers in little bags that have never been used. So since I'd always had issues with my mirrors coming loose when bouncing along bad roads, I've today switched to these washers from the bags. Hopefully they'll not come loose now
[ Time: 0.0178s ][ Queries: 4 (0.0093s) ][ live ][ 334 ][ ThingOne ]
