Sun Aug 28, 2022 8:56 am
Gilera Fuoco
Gilera Fuoco
Sun Aug 28, 2022 8:56 am linkquote
When I pull away on my 2010 Gilera Fuoco there is a "clacking" noise from the transmission.
I have had the cover off to check and all looks well as far as I can see.
Could it be the clutch unit?
Any advice would be welcome.
Benita
Sun Aug 28, 2022 10:02 am
2015 MP3 500 ie Business
Sun Aug 28, 2022 10:02 am linkquote
Are the washers all present and in the correct order?
Unless the shoes are worn, I am guess the clutch assembly is making contact with the cover.
Sun Aug 28, 2022 10:10 am
Gilera Fuoco
Gilera Fuoco
Sun Aug 28, 2022 10:10 am linkquote
Thank you for your reply.
I take it the the clutch comes off as a unit?
What should I be looking for in the way of spacers/washers?
Benita
Sun Aug 28, 2022 12:47 pm
Sun Aug 28, 2022 12:47 pm linkquote
Yes, the clutch comes off as a complete assembly.
Take a look at the diagram attached, particularly parts# 16 through 19.
The washers must be present and placed in the correct size and order. Another possibility is that the nut (part#16) is not tightened to spec.
Warning: Do NOT start the engine with the clutch cover removed or it will instantly disintegrate the clutch assembly.
https://www.easyparts.nl/explodedview/Originele-onderdelen-Gilera-Fuoco-500-IE-E3-2007-2013-(EMEA)-Koppeling-m14689-d42406
Mon Aug 29, 2022 10:14 am
Gilera Fuoco
Gilera Fuoco
Mon Aug 29, 2022 10:14 am linkquote
Thanks again for the information.
The diagram gives no indication of washer sizes
I will give it a try but it might be too technical for me,
What is the correct torque setting for the nut?
Thanks again
Benita
Mon Aug 29, 2022 1:13 pm
Mon Aug 29, 2022 1:13 pm linkquote
Thanks again
Benita
Page 12 of the workshop manual:
https://manuals.wotmeworry.org.uk/Gilera/Gilera%20Fuoco%20-%20MP3%20500/Fuoco%20Workshop%20Manual.pdf
Tue Aug 30, 2022 6:57 am
Gilera Fuoco
Gilera Fuoco
Tue Aug 30, 2022 6:57 am linkquote
Thanks for the information.
Benita
  DoubleGood Vespa Design
[ Time: 0.0289s ][ Queries: 5 (0.0082s) ][ Debug on ][ 211 ][ Thing One ]
