Mon Aug 29, 2022 12:54 am
Piaggio Mp3 Yourban 300ie
Mon Aug 29, 2022 12:54 am linkquote
Hi group. I have a problem with my bike. As
you can see on the video, it beeps. This only
happens sometimes while riding and if I swich
it of and turn it on again it works fine for a
while than starts beeping again. But there are
periods that I don't have problem with it for a
week or two.
When it beeps the roll lock is not working, but
when I switch it off and turn it back on again,
it works.
The seat sensor is working I show it at the end of the video
I check the dot4 container what is full so I have no idea what's wrong with my scooter
I can't upload the video
All suggestion are welcome
Mon Aug 29, 2022 6:49 am
2015 MP3 500 ie Business
Mon Aug 29, 2022 6:49 am linkquote
Define "checked the DOT4 container"
The 2 glass level indicators on the handlebar are only for the brakes.
Access to the tilt fluid container requires partial removal of the front end to get to it.
Tue Aug 30, 2022 3:10 am
piaggio mp3 hpe 300
piaggio mp3 hpe 300
Tue Aug 30, 2022 3:10 am linkquote
I had this problem also with my yourban.The problem was in the sensor plug, it was leaking oil. You can easily check this yourself by removing your front cover and removing the blue plug, if you see oil then you need a new pressure sensor.
Sat Sep 17, 2022 7:21 am
Sat Sep 17, 2022 7:21 am linkquote
Thank you very much
  DoubleGood Vespa Design
[ Time: 0.0268s ][ Queries: 7 (0.0054s) ][ Debug on ][ 211 ][ Thing One ]
