Tue Aug 30, 2022 3:38 am
Vespa GTS hpe 2022
Vespa GTS hpe 2022
Tue Aug 30, 2022 3:38 am linkquote
I was out n about on my new GTS hpe the other day - the night time arrived and I started to get flashed by passing cars. I think the headlight beam is too high as, on dipped beam, the road signs in the distance were lit.
Does anyone have any pics of the adjuster screw? It's not obvious.
This is my new steed
Tue Aug 30, 2022 3:43 am
LX190 Friday afternoon special, Primavera, some pushbikes
Tue Aug 30, 2022 3:43 am linkquote
There should be a screw below the headlight
https://www.manualslib.com/manual/804221/Vespa-Gts-250.html?page=61
Tue Aug 30, 2022 3:48 am
Vespa GTS hpe 2022
Vespa GTS hpe 2022
Tue Aug 30, 2022 3:48 am linkquote
It's the new LED light.
There isn't the screw as pictured in the manual on the new headset.
There is a cut out south west of the light. Inside (when a torch is shined in) there doesn't appear to be a screw adjuster.
Tue Aug 30, 2022 4:00 am
Tue Aug 30, 2022 4:00 am linkquote
Yes, its on the side for the LED light.
PG 72
https://cdnmedia.endeavorsuite.com/images/organizations/05211b9c-b6c7-4840-8e84-2970c2318c24/Owners%20Manuals/GTS%20300i%20HPE.pdf
Tue Aug 30, 2022 4:08 am
GTS 300ie Touring 2013 - Signora D'argento & GTS 300ie HPE 2022 - Regina Arancione.
Tue Aug 30, 2022 4:08 am linkquote
A nice looking GTS, welcome to MV!
Tue Aug 30, 2022 6:16 am
Vespa GTS hpe 2022
Vespa GTS hpe 2022
Tue Aug 30, 2022 6:16 am linkquote
I'm afraid I can't see an adjustment screw.
There is a hole in the headset. Up inside there is no screw.
I'm at a loss!
Anyone with a hpe led light can you help?
Tue Aug 30, 2022 8:57 am
GTS 300 hpe
GTS 300 hpe
Tue Aug 30, 2022 8:57 am linkquote
Have you checked your headlight against a wall? Always best to check first before changing any settings. Maybe no adjustment is necessary.
Tue Sep 20, 2022 5:01 pm
GT200L,300 Supertech
Tue Sep 20, 2022 5:01 pm linkquote
I'm at a loss!
Did you ever locate the adjustment screw? I was just trying tonight and could not find it with the screwdriver and flashlight.
Sat Sep 24, 2022 6:41 am
Vespa GTS300ie
Vespa GTS300ie
Sat Sep 24, 2022 6:41 am linkquote
At least vespa show how to adjust headlight in owners manual , Yamaha just say " have dealer make adjustments "
Sat Sep 24, 2022 9:13 am
GTS 300 Super
GTS 300 Super
Sat Sep 24, 2022 9:13 am linkquote
You have to take apart the handlebar cover with headlight attached and adjust the screw from the back of the headlight. And it does not say which way to turn the screws, it was pretty much trial and error and painful because every time you have to make small adjustments and reinstall the whole thing back together. I am extremely disappointed with vespa, I feel like they rushed to get the scoot off the assembly line. My cheapo bicycle lights are more bright at night.
Sun Sep 25, 2022 4:16 am
'07 GTS250ie "Mechanical Squirrel", '66 Honda Benly, '19 Suzuki 250 cafe "Mouse", '77 Jawa 350TS, '42 Henschel PzKw VI Tiger
Sun Sep 25, 2022 4:16 am linkquote
Agreed. I'm totally unimpressed with LED headlamps. While the beam cutoff is usually excellent the lamps seem to have no reach. My old quartz lamps seemed to reach much farther ahead with more intensity.
I recently retired after ten years working in the engineering of automotive lighting systems, mostly on LED units. They have a long way to go before I'd want them on my vehicle, but everybody seems to want to rush them to market.
  DoubleGood Vespa Design
[ Time: 0.0307s ][ Queries: 7 (0.0067s) ][ Debug on ][ 211 ][ Thing One ]
