When I pull away on my 2010 Gilera Fuoco there is a "clacking" noise from the transmission.
I have had the cover off to check and all looks well as far as I can see.
Could it be the clutch unit?
Any advice would be welcome.
Thanks
Benita
Gilera Fuoco
Posts: 8 Location: Northumberland |
Sun, 28 Aug 2022 16:56:37 +0000
quote
I have had the cover off to check and all looks well as far as I can see. Could it be the clutch unit? Any advice would be welcome. Thanks Benita |
2015 MP3 500 ie Business
Posts: 1062 Location: Belgium |
Sun, 28 Aug 2022 18:02:31 +0000
quote
Are the washers all present and in the correct order?
Unless the shoes are worn, I am guess the clutch assembly is making contact with the cover. |
Gilera Fuoco
Sun, 28 Aug 2022 18:10:35 +0000
quote
Thank you for your reply.
I take it the the clutch comes off as a unit? What should I be looking for in the way of spacers/washers? Thanks Benita |
Sun, 28 Aug 2022 20:47:39 +0000
quote
Yes, the clutch comes off as a complete assembly.
Take a look at the diagram attached, particularly parts# 16 through 19. The washers must be present and placed in the correct size and order. Another possibility is that the nut (part#16) is not tightened to spec. Warning: Do NOT start the engine with the clutch cover removed or it will instantly disintegrate the clutch assembly. https://www.easyparts.nl/explodedview/Originele-onderdelen-Gilera-Fuoco-500-IE-E3-2007-2013-(EMEA)-Koppeling-m14689-d42406 |
Gilera Fuoco
Mon, 29 Aug 2022 18:14:28 +0000
quote
Thanks again for the information.
The diagram gives no indication of washer sizes I will give it a try but it might be too technical for me, What is the correct torque setting for the nut? Thanks again Benita |
![]() The Hornet (GT200, aka Love Bug) and 'Dimples' - a GTS 300
Posts: 42811 Location: Pleasant Hill, CA |
Mon, 29 Aug 2022 21:13:22 +0000
quote
Benita wrote: Thanks again for the information. The diagram gives no indication of washer sizes I will give it a try but it might be too technical for me, What is the correct torque setting for the nut? Thanks again Benita https://manuals.wotmeworry.org.uk/Gilera/Gilera%20Fuoco%20-%20MP3%20500/Fuoco%20Workshop%20Manual.pdf |
Gilera Fuoco
