Sun Sep 18, 2022 2:23 pm
21 Racing 60s 95 Turbo RK
Sun Sep 18, 2022 2:23 pm linkquote
I get nervous seeing the torque specs on the Vespa fastners so I installed 12pt grade 12.9 fastners holding the wheels on and can torque to 30-32 ft lbs.
You guys move to higher strength bolts?
ARP fastners r your friend.
Sun Sep 18, 2022 2:29 pm
2012 Genuine Stella 150 4T "Penultimate"
Sun Sep 18, 2022 2:29 pm linkquote
Why spend the money?
There are tens of thousands of Vespas on the road and I don't recall "wheels falling off" as a common complaint. The OEM fasteners have stood the test of time.
Plus, the law of unintended consequences says that putting too strong of a fastener on, and torquing it higher than stock, will damage the thing it's attached to.
My .02. YMMV.
Sun Sep 18, 2022 3:37 pm
Sun Sep 18, 2022 3:37 pm linkquote
congratulations on finding the solution to a problem that did not exist.
anyway, enjoy your stripped hub when you disassemble it in the future.
Sun Sep 18, 2022 3:42 pm
Sun Sep 18, 2022 3:42 pm linkquote
Hopefully you mean that, while the bolt would be fine if torqued to such high value, there's no need (obviously). The point is the extra safety measure you feel important by having very strong bolts holding your wheels on at OEM torque.
Otherwise, yeah, this is an oil thread just not about oil.
Sun Sep 18, 2022 4:12 pm
2013 BV350, 2014 GTS , 2016 GTS, 2013 Downtown 300i
Sun Sep 18, 2022 4:12 pm linkquote
They're much more likely to corrode solidly in place than fall out.
Sun Sep 18, 2022 4:43 pm
Sun Sep 18, 2022 4:43 pm linkquote
My .02. YMMV.
^^^this
^^^ and this
Sun Sep 18, 2022 4:49 pm
Sun Sep 18, 2022 4:49 pm linkquote
If one uses lubricant on fastners the torque value needs to be adjusted by the lubricants rec coefficient reduction.
Having built hundreds of engines, transmissions, and rear differential, I will never and have never dry assembled anything. Lubricants are your friend. Just like ones, bolt stretch measuring equiptment.
Always use the strongest fastners available on stuff
The bolts on vespas and most most OEM parts are good/adequate, I perfer to use excellent.
Plus premium quality fastners are better appearing too.
Sun Sep 18, 2022 5:00 pm
LX190 Friday afternoon special, Primavera, some pushbikes
Sun Sep 18, 2022 5:00 pm linkquote
Sun Sep 18, 2022 5:21 pm
Sun Sep 18, 2022 5:21 pm linkquote
So many contradictions, so many questions, so little time before I go to bed....
But, so I have something to read when I wake up, if "strongest fasteners available" is really your goal, how do you feel about torque-to-yield?
Sun Sep 18, 2022 5:51 pm
GTS 300 hpe
GTS 300 hpe
Sun Sep 18, 2022 5:51 pm linkquote
The torque specs do not only take the bolts into account, but as Greasy points out, also the wheels themselves. Are you changing those too so they too can withstand the torque? Anything fastened has two ends, no?
Sun Sep 18, 2022 6:19 pm
Sun Sep 18, 2022 6:19 pm linkquote
Add a bit of duct tape if you're worried.
Sun Sep 18, 2022 7:55 pm
Sun Sep 18, 2022 7:55 pm linkquote
Or self-sealing stem bolts...
Mon Sep 19, 2022 12:44 am
Mon Sep 19, 2022 12:44 am linkquote
Ah yes, that "Bigger is always better" myth.
Mon Sep 19, 2022 5:43 am
Mon Sep 19, 2022 5:43 am linkquote
OEM components are the manufacturer's economic solutions to any given scenario.
There are ALWAYS alternatives that are declined because of cost.
An example is putting grey or steel appearing bolts connecting color coated wheels to a vechicle
Higher cost, color coordinated, higher strength, longer lasting etc components have always been relegated to the aftermarket.
Some people will settle for OEM, others seek improvement.
Mon Sep 19, 2022 6:00 am
Grumpy Biker
Grumpy Biker
Mon Sep 19, 2022 6:00 am linkquote
On my car, I use ARP head bolts and ARP wheel studs + forged lugs + forged wheels. But on a Vespa? Nah. Seems like I would just be spending money on a problem that doesn't exist. I've never heard anyone report a broken wheel stud on a Vespa.
I only use these products on my car because stretched head bolts can be a problem on cars running higher than stock boost and under track conditions, I have seen broken wheel studs. Both of these situations apply to my vehicle.
Mon Sep 19, 2022 10:35 am
GTV300 (wife's)
GTV300 (wife's)
Mon Sep 19, 2022 10:35 am linkquote
I guess one would have to know if the part the bolt threads into has more strength than the threaded part of the bolt. I mean would using a 12.9 bolt that is threaded into cast aluminum actually give you any more of secure joint?
Now if you want to change from say an Allen head bolt to a 12 point bolt because you like the looks better that might be fine. But I would not change the torque to assemble the component just because the fastener might be capable of the higher torque.
Mon Sep 19, 2022 10:42 am
GTV300 (wife's)
GTV300 (wife's)
Mon Sep 19, 2022 10:42 am linkquote
Or use a dab of yellow paint that covers the intersection of the head of the bolt and the wheel. That way if there is movement you will see the crack in the paint.
Or better yet how about lock wire them like airplanes and race cars?
https://www.aircraftspruce.com/menus/to/safetywiretools.html
Mon Sep 19, 2022 10:45 am
GTS 250
GTS 250
Mon Sep 19, 2022 10:45 am linkquote
This might upset some people...
Mon Sep 19, 2022 12:21 pm
Grumpy Biker
Grumpy Biker
Mon Sep 19, 2022 12:21 pm linkquote
^^^^ This is done for aesthetic reasons. I'm on board with that. When you're building a custom machine you do all sorts of things to get a certain "look" or improve the OEM look. I'll buy that. But I won't buy that the improved fasteners make the machine any safer (unless you are somehow putting it under a lot more stress).
By the way... the process of chroming hardware actually had a detrimental impact on it's strength. I try to always avoid chrome hardware for that reason. If I want something that looks flashy, I'd rather polish stainless hardware.
Mon Sep 19, 2022 12:59 pm
Mon Sep 19, 2022 12:59 pm linkquote
gee, you could've just said: I like the way chrome 12-point bolts look instead of all that other blow-hard jibber-jabber.
Mon Sep 19, 2022 2:17 pm
Mon Sep 19, 2022 2:17 pm linkquote
This is an example of why I now and never did pay much attention to seargents.
I chose to use ARP polished 12pt ss fastners and coated mating surfaces of wheels with anti seize.
The steel/ aluminum will survive and prosper under ARP rec torque loads.
I even threw the pos gas cap out and use one from a 946 because it is heavier duty. flame away children
PS.
THAT POLISHED CHROME MODDED MOTOR LOOKS GREAT.
Mon Sep 19, 2022 2:26 pm
Mon Sep 19, 2022 2:26 pm linkquote
That chrome motor is hot.
Because shiny stuff doesn't dissipate heat so well.
Mon Sep 19, 2022 2:41 pm
GTS 250
GTS 250
Mon Sep 19, 2022 2:41 pm linkquote
Some more in-progress shots.
Mon Sep 19, 2022 2:45 pm
Mon Sep 19, 2022 2:45 pm linkquote
that's sharp looking! the attention to detail is impressive!
Mon Sep 19, 2022 3:17 pm
2015 GTS 300 Super (Melody: 2015-2021, RIP) 2022 GTS SuperTech (Thelonica)
Mon Sep 19, 2022 3:17 pm linkquote
In terms of this thread, my take is: the perfect is the enemy of the good.
In regard to AnnDee4444: play on, friend, that thing's a knockout. And probably worthy of aftermarket bolts in numerous places.
Mon Sep 19, 2022 3:32 pm
2019 Supertech (EURO3/APAC)
Mon Sep 19, 2022 3:32 pm linkquote
Not sure what you're doing with the rocker cover breather ...
Mon Sep 19, 2022 3:45 pm
GTS 250
GTS 250
Mon Sep 19, 2022 3:45 pm linkquote
Just venting to atmosphere for now. That's just the OEM hose with a filter on the end.
I'd like to rig-up a proper PCV, but don't really want to use the OEM intake box. Any ideas?
Mon Sep 19, 2022 4:14 pm
Mon Sep 19, 2022 4:14 pm linkquote
Couldn't you plumb it into a "T" in the intake hose, downstream of the filter?
Mon Sep 19, 2022 4:30 pm
GTS 250
GTS 250
Mon Sep 19, 2022 4:30 pm linkquote
Yes, but I'd really rather have some sort of air/oil separator.
You know how the stock intake "bulbs" fills with oil? Dumping that into the intake isn't ideal.
Mon Sep 19, 2022 6:31 pm
GT 2.4
GT 2.4
Mon Sep 19, 2022 6:31 pm linkquote
Agree. i think a good place to replace the stock fasteners with 12.9 allens would be the two bolts that hold the swingarm to the engine or the bolts that hold the exhaust to the 50-150. Those snap off frequently.
Mon Sep 19, 2022 9:10 pm
Mon Sep 19, 2022 9:10 pm linkquote
It's on my list of projects to do. Just haven't yet worked out a good mounting place
Tue Sep 20, 2022 8:13 am
GTS 250
GTS 250
Tue Sep 20, 2022 8:13 am linkquote
My obsession started when I snapped an exhaust stud. I figured out that it was due to the OEM nut size combined with the PM tuning exhaust... the tightened nut would spread the studs apart and eventually broke (~5000 miles).
I found that the ARP nuts were smaller in diameter and allowed the clearance needed. Also they're a little bit easier to get started when the motor is in the bike.
Wed Sep 21, 2022 4:31 pm
Wed Sep 21, 2022 4:31 pm linkquote
Smaller size, stronger STRENGTH, and spline heads are what got me buying ARP.
Their use on connecting rod bolts minimized the amount of material needing to be removed from the 331 354 392 blocks to use longer stroke cranks.
Wed Sep 21, 2022 9:28 pm
bv350, Brutale 910
bv350, Brutale 910
Wed Sep 21, 2022 9:28 pm linkquote
twss
Tue Sep 27, 2022 6:08 am
Tue Sep 27, 2022 6:08 am linkquote
ARP part nos that replace factory wheel bolts;
Complete kit all 5 fastners w washers;
Polished stainless steel w washers 771-1005
Black chrome moly w washers 671-1005
I use ss front cm rear.
Both MUCH stronger, both polished finish, WITH anti rust surfaces.
Torque to 24 ft lbs
Very nice upgrade to the appearance of front wheels and over grade 5 factory stuff
Ebay Amazon carry all
  DoubleGood Vespa Design
[ Time: 0.0359s ][ Queries: 7 (0.0117s) ][ Debug on ][ 211 ][ Thing One ]
