Sun Sep 18, 2022 2:52 pm
'81 Vespa P200e, '85 Vespa PX125e, '70 Vespa 90 basketcase
Sun Sep 18, 2022 2:52 pm linkquote
Hey all, I've noticed a discrepancy with my scooters here.
I have a p200e. Bone stock with a sip road 2 exhaust. The spark plug I have in the engine is a b8es (long threads) the bike runs like a top.
I have a second scooter with a p200 engine in it. Freshly built. The bike wasn't running right. I had a b8es in it. But the plug looked chocolately when I checked.
I then checked the Haynes manual and it calls for a b7hs (short threaded) plug.
I put that in the bike, and it ran so much better.
When I got home and checked the plug, it was very lean.
So why the discrepancy in performance? Was it just running leaner? Or was the plug and the thread length make that much of a difference?
Which plug is the right one? Is the Haynes manual incorrect?
Reading about spark plugs on the forum and it is littered with answers of p200e requires a b7-8es plug.
Can anyone clarify?
Thank you!
N
Sun Sep 18, 2022 11:12 pm
Parmakit Primavera -74, Polini Primavera -68, Stock 150 Touring -59, VMC 177 Bajaj Chetak 125 -95
Sun Sep 18, 2022 11:12 pm linkquote
You should always run a plug thread lenght that matches your head.
The number on NGK plugs is a heat value. Lower number is slower to get rid of heat and runs hotter while higher numbers transfer heat faster to the head and thus run cooler.
Running too cold plug ends up coking itself up and too hot will melt in the extreme situations. Between these two is a zone where plug is hot enough to burn the crap off but still not hot enough to melt.
Coffee brown is good color for plug. Post images of your plugs so we can see what they look like.
Mon Sep 19, 2022 12:03 am
125 GTR 1977, 50S 1975, GTS 125 Supertech 2021
Mon Sep 19, 2022 12:03 am linkquote
One thing often underrated is the fact that when you use a wrong length spark it affects compression - A longer spark plug can reduce the chamber in 1cc which my rough calculations is 5 to 10% of the combustion chamber size on a 150-200cc engine.
Mon Sep 19, 2022 10:22 am
1958 Allstate 177VMC, 2005 70cc Yamaha Vino
Mon Sep 19, 2022 10:22 am linkquote
1% of 150cc is 1.5cc mate. 10% would be 15cc.
Mon Sep 19, 2022 11:30 am
Mon Sep 19, 2022 11:30 am linkquote
Where should the bottom of the plug be situated if I matched the threads of the plug to the head?
How deep should the plug be?
Thank you.
Mon Sep 19, 2022 11:40 am
Jet Eye Master
PX221 MHR, O tuned PX200, PX181 Quattrini and some motorbikes
Jet Eye Master
Mon Sep 19, 2022 11:40 am linkquote
Thank you.
P200 has an ES plug. If bone stock it should be a B7ES.
If using a higher number plug (like 9) when not needed, it can give the illusion of running ok (tan) and actually on a 7 plug it would be running white.
Mon Sep 19, 2022 8:27 pm
Mon Sep 19, 2022 8:27 pm linkquote
Thank you.
The threads should not be visible when the plug is all the way in. With long plug on a short threaded head the threads of the plug are visible on the combustion chamber. The other way around the threads on the head are left exposed.
On many engines using too long plug will cause the plug to contact the piston top. This is not the case though with original Vespa heads with huge combustion chambers.
Tue Sep 20, 2022 5:53 am
Tue Sep 20, 2022 5:53 am linkquote
Wrong, mate
Combustion chamber is not 150cc, that's the cylinder + combustion chamber
On a 1/10 compression ratio engine, 150cc is compressed to 15cc, thats the combustion chamber volume
  DoubleGood Vespa Design
[ Time: 0.0293s ][ Queries: 5 (0.0081s) ][ Debug on ][ 211 ][ Thing One ]
