Sun Sep 18, 2022 5:47 pm
2022 GTS Sport
2022 GTS Sport
Sun Sep 18, 2022 5:47 pm linkquote
Hello
I think the spring is much too powerful on the Vespa GTX 300 front rack.
I do not understand why they installed such a powerful spring set on this rack.
If someone knows please comment
I will be removing one or both springs on mine.
Sun Sep 18, 2022 11:43 pm
2017 GTS300 + 2007 LX50 2020 Kawasaki Versys 1000 1994 Piaggio Ciao
Sun Sep 18, 2022 11:43 pm linkquote
Why is light blue so hard to read!
Anyway, I actually liked the powerful spring, when I still had the front rack attached. Because of the power of the spring, the rack won't start to rattle on bumpy roads.
Sun Sep 18, 2022 11:53 pm
Medley 150
Medley 150
Sun Sep 18, 2022 11:53 pm linkquote
It's to carry full strength beer.
Sun Sep 18, 2022 11:58 pm
LX190 Friday afternoon special, Primavera, some pushbikes
Sun Sep 18, 2022 11:58 pm linkquote
Are there any blue pills in the pet carrier?
Mon Sep 19, 2022 12:39 am
Mon Sep 19, 2022 12:39 am linkquote
The yellow ones are much better...
Mon Sep 19, 2022 8:56 pm
GT 2.4
GT 2.4
Mon Sep 19, 2022 8:56 pm linkquote
onevw wrote:
Hello
At one point in their history, Piaggio had an ACME division that was responsible for improving products like the front rack and making Cars. The original front rack was easy to remove from the scooter. Theft was a big problem. The ACME division replaced the original spring with two that were used to hold garage doors up in Italy. There was a latch and tab that could be used to hold it down like a mouse trap. if anyone tried to steal it, the rack closed and held the thief until the carabinieri arrived.
They probably ordered too many springs.
if you want to know painful, lift up an italian scooter with a sidestand while wearing flipflops.
Tue Sep 20, 2022 12:56 am
2019 Supertech (EURO3/APAC)
Tue Sep 20, 2022 12:56 am linkquote
they are strong to reduce rattle.
the springs on my rear rack broke. I removed them and since I always have the top box on, I don't miss them.
Thu Sep 22, 2022 4:38 pm
2015 GTS 300 Super (Melody: 2015-2021, RIP) 2022 GTS SuperTech (Thelonica)
Thu Sep 22, 2022 4:38 pm linkquote
Probably not the ACME I knew as a kid...
Rumor has it that WEC side-gigged designing aftermarket parts for Lambrettas back in the day.
Fri Sep 23, 2022 4:36 pm
GT 2.4
GT 2.4
Fri Sep 23, 2022 4:36 pm linkquote
Have you ever seen a roadrunner in Italy? Now you know why.
Sat Sep 24, 2022 3:35 am
2019 Primavera 150, 2019 Honda Super Cub 125, 2017 Honda Metropolitan, 1965 Honda Super Cub 50 CA102
Mon Sep 26, 2022 5:43 pm
2022 GTS Sport
2022 GTS Sport
Mon Sep 26, 2022 5:43 pm linkquote
I did remove both springs.
And as Steelbytes and others have said these springs put pressure on the pivot joint shaft and push the pivot shaft against a very loose bracket hole where the pivot shaft rotates. No spring and the shaft bounces all over the place.
  DoubleGood Vespa Design
[ Time: 0.0276s ][ Queries: 7 (0.0063s) ][ Debug on ][ 211 ][ Thing One ]
